i have a cube u30gt2 @ 4.2.2 from here: http://www.arctablet.com/blog/forum/cube-u30gt2/cube-v2-06-20131029-kasty-rom-darthjabba-mod-in-cwm-upgrade-format
i have used all kernels by DarthJabba , but i can't enable usb host mode.
i have many otg cables and many usb hub.
the usb hub not recognized by the system to connect my devices.
any ideas ?
thanks in advance
** sorry for my bad English (google translate)
Is there our hubenable.ko module in the build? Look at /system/lib/modules.
Load Terminal Emulator from Play Store and type:
su
insmod /system/lib/modules/hubenable.ko
lsmod
The module should now running. Try your USB-Hub.
You can see the devices in the app USB Host Controller.
Try again to load the hubenable.ko and make sure the module is running (lsmod).
# lsmod
lsmodhubenable 565 0 [permanent], Live 0x00000000
rk29_ipp 9957 1 - Live 0x00000000 (C)
mali 152212 15 - Live 0x00000000
ump 27958 13 mali, Live 0x00000000
rk30xxnand_ko 162075 0 - Live 0x00000000
root@grouper:/ #
Ok, fine. Anything is like it should.
You may need to find a working OTG-cable.
45 Guest(s)
Devices in use: Desktop (36), Phone (9)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
