2013/04/16
Only if the rom installed on your tablet is the test version 2.04:
I had the same problem and even thought it was defective, but then I realized that the HDMI only works if the tablet is with the native resolution.
In menu, CONFIGURATION, DISPLAY, DISPLAY MODE, have the option NORMAL or HD. Make sure that the option is in HD.
2013/06/01
Cassius Brandhuber said
Only if the rom installed on your tablet is the test version 2.04:I had the same problem and even thought it was defective, but then I realized that the HDMI only works if the tablet is with the native resolution.
thanks.
A question before i try that - How do you cnnect it to TV?
I use cable like this one -
59 Guest(s)
Devices in use: Desktop (49), Phone (10)
cutierogue
