2013/04/23
maikal said
memory occupation after first wake up: 55% before 65% (with DJ) chinese animation very very long longer than DJ Â ??? Â it seems (it is like ) DJ except startup logo byeÂ
So it begs the question aain is there anywa to shorten that chinese anmatin? Or just plain remove it?Is it that difficult? Admin? Darthjabba, your thoughts on that animation? It is overly long even with bootmanager on.
No idea.
2013/04/23
2013/09/04
Thanks for the links
The film was not yet known to me.
Have been playing me the new Rome.
Hoping to use the current recovery with get shut.
Here the file
[ROM] Android 4.2.2 custom U30GT2 cube root firmware version 2:06 final (10/29/2013)
However, I have since still the Recovery Version 4.2.01.
How do I get now di 6.0.3.1 on the cube.
Want to try the overclocked kernel.
2013/06/15
HI siporax
extrem procedure
1 instal "cube_u30gt2-422-204_20130810-cwm_rooted4d" with Rockchip_Batch_Tool_v1.7
2 go to cwm with artools reboot
3 install "kasty_422_206_20131029_krnl38_OC_darthjabba_201310302104" in cwm mode
n install any kernel zips from DJ or "DJ russian" to go elsewhere
... after that for me
better wifi
no hot point on the back (with some flight simulator)
better stability
I use 158 diverse apps
thanks to many guys
regards
2013/07/09
2013/06/15
@maikal
I have just reinstalled my cube with that procedure
I have just having heat when using flight simulator for a long time with "Krnl 12 OC" from russian banks, my cube has a leather cover
I test many apps 5 hundreds and their updates, near 158 installed so I reinstall from time to time and appmonster backups made that easy
I think that now my cube is in its best states; but I remarked that with the same procedure the new cube states is not always so good ??????????????
Perhaps after using and testing some modules from frame
regards
2013/07/09
Okay Val that explains it.
So last night I also took a test drive of 12 oc and it was a disaster. I did the cache and dalvick clean up, but the initial first screen kept rebooting itself. First the initial animation, like 3 times then it would park on the arctool logo for a few seconds then it would redo initial animation (very nice logo too bad) then back to arctool before eventually doing chinese animation again. It did this several times before I managed to get on desktop. But then it would FC by itself.
So I reflashed it just to see what happened and I got to tell you I thought I lost the baby there. Same thing again and much more worse. IT actualy reversed the booting to cwm from start up. instead of power+ I had to power- to finally get to cwm. So after much sweating and "oh crap oh crap", I managed to once again get to desktop, reflashed the darthJabba 38 OC special, and the seas parted, the sun came up and I am not sure, but I think that was an apparition of Darth Jabba surrounded by the sun in a white robe! Everything was back to normal!!!
Sooo, thank you again DarthJabba for a great construct and all the hard work you been doing on here...Just one question...do you really have a golden beard?...lol
Cheers Indeed!
validatus, Ohamn
2013/04/23
Hmmm ... you probably saw the Archangel Michael, not me!
In all seriousness, I have not experienced any problem with kernel 12, which I have used for a few days. Right now, I am using another version of it, as overclocked by supersport900 in the freaktab forums (http://www.freaktab.com/showthread.php?8032-Cube-U30GT-2-v2-06-20131017-900supersportROM/page2). That version has had the gpu overclocked to 798mhz and the DDR overclocked to 720mhz. So if any kernel 12 should cause problems, it should be this one - but so far, no problems (I even got a score of 21009 on Antutu).
Ohamn, maikalDarth Jabba, the Dark Jedi from Nal Hutta
2013/11/18
i have the same problem with the overclocked kernel as maikal said.
After installation i have a lot of reboots and fc. No Problem with the stock kernel in the same situation.
My rom is the "kasty-cube_u30gt2-422-206_20131029-rooted4.zip".
Ist it possible that my tablet has a problem with the undervolting or the higher gpu settings?
Thanks for your great work DarthJabba!
87 Guest(s)
Devices in use: Desktop (71), Phone (15), Tablet (1)
makaryura
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
