Cube v2.06 20131029 Kasty ROM - Darthjabba mod in CWM upgrade format
Al
Forum Posts: 19
Thanks Received: 4
121
2013/11/22 - 02:36
Hi got Netflix to work on this ROM with the patch under Xposed. You can download the patch here.
https://www.dropbox.com/s/d5ifqqwh0zylj5g/XposedCM10-10.1NetflixWorkaround-Dinc.apk
 Got it from here:
http://www.freaktab.com/showthread.php?5017-NEW-Imito-MX1-2-JB-4-2-2-Finless-ROM-2-0&p=101160&viewfull=1#post101160
Did a 5 minute test with the most resent version of Netflix and worked fine....
The following users say thank you to Al for this useful post:
DarthJabba, lugs, thatoneguysomeplace
jy_p
Forum Posts: 44
Thanks Received: 20
122
2013/11/22 - 19:36
Do you have the Multi-Windows in this ROM?
--webjo--
Forum Posts: 11
123
2013/11/22 - 20:43
I installed this rom on my tablet, I want to make a restore of a backup that I made but I have this "picture Error while flashing boot" error message I renamed my backup folder and I think the problem come from, it seems to me that there is a solution to recover my backup but I do not remember. I however already renaming a folder and I had not had any problems but it may be because-I installed another ROM. Thank you for your help
sorry for my english I'm french
sloed
Forum Posts: 14
124
2013/11/22 - 21:44
My Netflix is working now. Thank you, thank you, thank you. I installed the work around yesterday and it would not work. I did reboots still nothing.  So this morning I thought I would give it one more try and TA DA it was working. Thanks Again.
--webjo--
Forum Posts: 11
125
2013/11/23 - 12:33
can be installed recovery Phil TouhZ ?
sadness
Forum Posts: 11
126
2013/11/23 - 15:14
i can't watch streams over browsers.. it says "Pause adblock for this site in order see streams"
what should i do?
lugs
127
2013/12/06 - 18:12
Re-installed this ROM, installed the Netflix xposed patch, sorted......Thanks for the great work guys.
andyffoo
Forum Posts: 16
128
2013/12/08 - 05:42
Thank you for your work. Has anyone found the following?
This rom as well as the other v2.06 rom takes ages to get going. After switching on, then lag, lag, lag. Even for very simple tasks. 10 mins later the lag finally disappears. Then I update an app and then more lag, lag. I have to put the tablet down for a while as it becomes unusable until if has finished updating.
Games seem to work well though.
To put things in prospective, I find it quicker to use my HTC HD2 phone running 4.3 jelly bean (>4 years old) to send an email or check a website.
This is surely not right!!
jrgalang
Forum Posts: 17
Thanks Received: 6
129
2013/12/08 - 08:08
Înstall kernel 12 or kernel 12 OC from the ZIP provided on the other thread. Fixed those issues for me.
The following users say thank you to jrgalang for this useful post:
andyffoo
andyffoo
Forum Posts: 16
130
2013/12/08 - 17:35
jrgalang, thank you.
Kernal 12 oc works a lot better than kernel 38oc with this rom. Far less lag. It has really made the tablet a lot more productive and less frustrating.
Still get a lot of lag initially when I change users but it resolves after 5 mins. This is understandable as I presume the tablet is slowed down temporarily as it loads all the new user apps and settings.
Cheers
tommyx
Forum Posts: 24
131
2013/12/09 - 23:38
Nice ROM. Thank you! I only have 2 complaints :) .. No display resolution change option in display settings menu and multi window option crashes every time. When I switch it on settings menu crashes when I click the button in the upper right corner it also crashes. Everything else seems to work fine. Any idea how to fix the two issues? Thank you.
don't
katana1
132
2013/12/11 - 13:13
i have the rom with 38oc Kernel on my tablet, and it works very fine.
Thank you for this great work.
But i have one problem, VPN doesent work.
There is no tun.ko in the Kernel and without it VPN doesent work.
Is there a chance to get a working tun.ko for this kernel or is there a other kernel which work with VPN?
jy_p
Forum Posts: 44
Thanks Received: 20
133
2013/12/11 - 14:57
katana1 said
I use Tun.ko installer.  Works fine for me.  But you have to re-run it after each boot.
Does anyone knows how to permanently install one?
Does anyone knows how to install a CISF module?
katana1
134
2013/12/11 - 15:30
Thank you for this information i will check this out.
I found in an other forum this.
If the tun.ko is on your SD-Card you have to do this in a terminl with root.
Code:
mount -o remount,rw /dev/block/mtdblock4 /system
mkdir /system/lib/modules
chmod 755 /system/lib/modules
dd if=/mnt/sdcard/tun.ko of=/system/lib/modules/tun.ko
chmod 644 /system/lib/modules/tun.ko
rm /mnt/sdcard/tun.ko
insmod /system/lib/modules/tun.ko
mount -o remount,ro /dev/block/mtdblock4 /system
But i havent found an tun.ko yet.
If the tun.ko installer work there must be an tun.ko on the tablet and then you can install it permanently.
cifs.ko schould work similarly.
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
135
2013/12/11 - 16:04
"Does anyone knows how to install a CISF module?" I think someone had posted a XDA link to it in one of the last 2 or three rom threads.
Lets keep in mind that some people will have a problem with #12 Kernel, and some will have problems with #38 kernel. I have been unable to make any #12 kernel work on my tablet, the #38 kernel zips have worked fine for me! I am currently on a version of #38 that works great for me, it may not to some whose tablet works better with a #12 kernel. Completely weird to me how that happens, but it may be due to the differerent apps or additions we have made to the tablet since we have been fiddling with it.
I had planned on flashing the original firmware, sort of using it like "pepto-bizmol" to clear everything on the tablet , then just flash the best working rom I have experienced to-date and just sit on that until the kit-kat roms begin...lol. Then I can start playing the flashing game again...lol. But seriously I think my tablet could use a thorough cleansing and re-start before going forward flashing and re-flashing stuff into it, and perhaps that something to think about for all of us.
To be honest, I am game for testing anything right now, I am using my tablet to learn what I can, I do plan on getting another one if my tax return from uncle sam works out, but if not I'll save my pennies and get another one that I can apply what I learn from this one, and update only when I have tested it first on this current one.
So again thanks to everyone that has posted solutions and ideas here, even the most minor one has contributed to my learning how best to tinker with my Cube.
91 Guest(s)
Devices in use: Desktop (79), Phone (10), Tablet (2)
beppebettini58@gmail.com
marcodigio77
marcodigio
dimitrifrom31
svilbg
theelf
