Cube v2.06 20131029 Kasty ROM - Darthjabba mod in CWM upgrade format
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
76
2013/11/06 - 13:24
HI DJ
What about:
system/media/rkfactory/default_wallpaper.jpg
system/media/bootanimation.zip, bootanimation_0.zip, bootanimation_1.zip
 it seems that "search image editor" can save .jpg, .bmp to .bin
where is boot_logo, logo.bin,  (if there ...)
thx
The following users say thank you to validatus for this useful post:
thatoneguysomeplace
DarthJabba
Forum Posts: 551
Thanks Received: 396
77
2013/11/06 - 22:13
Chuck Borris said
kikeminchas said
Hi guys,
What is your battery consumption in stand by with DathJabba's latest? (no overclocked kernel). Mine rounds the 1% per hour on average... I have removed phone apk's. Tablet enters fine in deep sleep, no wakelocks. WIFI is off... I think this consumption is excessive but I somehow don't think I have a defect battery, it lasts around 5-6 hours navigating with WIFI on and around 7 hours reading comic books... what's your experience?
Hy, i have overclocked version. Did the same things you did (phone.apk, wifi) and I have the same experience as you do. Power drain cca 1% per hour in stand by.
I think i'll have to go back to 07082013 darthjabbas version
1% per hour is decent - that amounts to about 4 days on standby. My Android phone fares much worse than that.
Uznamer
Poland
Forum Posts: 42
Thanks Received: 12
78
2013/11/06 - 23:36
@DarthJabba. I am on your last overlocked mod and my Cube was idle almost five days as I had no time to use it. Within 110 hours it lost 56% of its energy and it means only 0.5% per hour. To say it is decent result is not enough. It is just amazing!
DarthJabba
Forum Posts: 551
79
2013/11/07 - 09:36
validatus said
HI DJ
What about:
thx
Sorry, but I know little about these things. The boot animation files contain scores of bitmaps that are displayed in rotation (to create the impression of animation) while the tablet is booting up. Someone with plenty of time and patience can probably create his own and use them to replace what is there at the moment - but what would be the point?
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
80
2013/11/07 - 10:23
Hi, DJ
this is on the CUBE from kernel OC38
perhaps renaming one it is possible to replace animation, ??
perhaps renaming one it is possible to replace wallpaper, ??
many bootanimation are ready on www, ??
regards
Chuck Borris
Forum Posts: 20
Thanks Received: 7
81
2013/11/07 - 10:26
DarthJabba said
Chuck Borris said
kikeminchas said
Hi guys,
Oh! :) Cool! :) )
But I think that on previous version (07082013) results were even better... I'll recheck as soon as I'll have time (at the end of next week) and report back.
DarthJabba
Forum Posts: 551
82
2013/11/07 - 10:28
Well, you can always try replacing them with your own. All you need is to use something like ES File Explorer to make the system partition writable, and then copy your own files over.
validatus
tommyx
Forum Posts: 24
83
2013/11/09 - 00:03
Hey thank you for the New rom .
One question .. I having heavy Speed problems with the internal and external SD card. I tested this with this and the older 2.03 Rom. With the old Rom i habe about 3 -5 MB/s internal and external what is slowSD cache ut bearable. But now i have 1 MB/s and below. I can send a Screenshot. The Boot time of the tablet is now over 2 minutes (i actually stopped the time :-) i tryed the external SD in my Smartphone .. Everythings fine. The Problem is that now everything is very slow. Working with es file Explorer is extremely slow and therefore very very annoying. Please help me. Thanks.
Update ... I change the sd cache to 6192 kb ... This helps a bit but not much. I counted how often the logo @startup is looped until i can unlock my screen . 31 times . can somebody tell me if this is normal? Because with the above mentioned old rom it sometimes took about 10 to 20 secs. To boot.
don't
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
84
2013/11/09 - 12:03
Hi DJ
I (re) install
http://www.arctablet.com/users/forum/kasty_422_206_20131029_krnl38_OC_darthjabba_201310302104.zip
changes are made
all my system is kept
correct ?
regards
Jgarciaillanf1
Forum Posts: 35
Thanks Received: 13
85
2013/11/09 - 14:41
My Cube is on Cube animation after flashing the ROM, what can i do?
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
86
2013/11/09 - 15:32
@Jgarciaillanf1
how did you flash the cube
DarthJabba
Forum Posts: 551
87
2013/11/09 - 15:42
validatus said
Hi DJ
I (re) install
changes are made
correct ?
Yes.
validatus
Jgarciaillanf1
Forum Posts: 35
Thanks Received: 13
88
2013/11/09 - 17:57
validatus said
@Jgarciaillanf1
Install CWM, do Backup, flash Kasty ROM... and get bootloop.
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
89
2013/11/09 - 18:41
@Jgarciaillanf1
what was the rom before flashing
what rom used for flashing: Kasty, Kasty-DarthJabba
I am thinking that your way of flashing didn't erase the previous rom ...
I think you have to use rockchip 1.7 and do a restore, all wiping ...
CAUTION: all data cancelled, do backups, remove external sd
 ACCEPT all restric tions linked with proposed roms
regards
Jgarciaillanf1
Forum Posts: 35
Thanks Received: 13
90
2013/11/09 - 18:53
validatus said
@Jgarciaillanf1
regards
Stock ROM rooted.
Kasty + DJ mod.
So... should i restore with RK 1.7¿?
I don't understand that tool so much...
Thanks.
98 Guest(s)
Devices in use: Desktop (92), Phone (6)
Freyagtt123
Freyagtt
MattSays03
MattSays
Dus_89
osamaxx101
