Cube v2.06 20131029 Kasty ROM - Darthjabba mod in CWM upgrade format
robiom
Norwich, UK
Advanced Member
Forum Posts: 124
Thanks Received: 27
61
2013/11/04 - 12:54
validatus said
@robiom
Two kind of updates
ROM with oc#38 kernel (this is a 206 restore which destroys all)
Kernel with oc#38 (this is an update of kasty DJ 204 to 206 nothing destroyed)
both astonishing updtes
thanks to kasty & DJ
regards
So to be clear, is #38 O.C. kernel compatible with 2.06 ignoring the fact any improvements Cube
has made?
Rob
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
62
2013/11/04 - 14:36
@robiom
I am not a specialist
ask Kasty or DJ
but I installed "CWM update
http://arctablet.com/users/forum/kernel38_overclocked_darthjabba_201310171913.zip"
on a kasty 204 rom
I kept my system
and CUBE says "Numéro de build V2.06 ... I am french !"
regards
DarthJabba
Forum Posts: 551
Thanks Received: 396
63
2013/11/04 - 20:09
has made?
As far as I am aware (i.e., from my own experience on my Cube), yes.
robiom
sadness
Forum Posts: 11
64
2013/11/05 - 11:08
maikal said
sadness said
Chuck Borris said
Chuck Borris said I sadly have to report ther is a major power drain on standby if the wifi is on. Went from 100% to 90% in couple of hours. After turning wifi of it went from 82% to 81% during the night (8 hours) Darthjabba how can i achive that wifi would automaticaly turn of after locking (as is in most of your mods)
could you explain
how did you manage it? i can't make wifi on after screen lock
When i activate screen again in the morning, the first thing is, that i turn wifi on again... Nothing complicated...
i guess you have misunderstood me... i mean i couldn't make wifi "always on".. whatever i did wifi turns its off when screen sleeps
Go to your settings-->wifi-->advance--> keep wifi on during sleep-->always. Thats how I have mine set up. If that does not work tell us what you tried.
we are both using same settings, but wifi turns off during sleep
080200
Forum Posts: 18
65
2013/11/05 - 16:24
i have this rom now and my wifi stays always up
Jgarciaillanf1
Forum Posts: 35
Thanks Received: 13
66
2013/11/05 - 17:37
Hi everyone.
If i decide to flash this ROM... will be a problem if i'm in 4.1.2 firmware right now?
Thank you guys.
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
67
2013/11/05 - 17:42
@Jgarciaillanf1
no problem if u do a rom restore
but 4.1.2 means it's original : so backups
regards
The following users say thank you to validatus for this useful post:
Jgarciaillanf1
Jgarciaillanf1
Forum Posts: 35
Thanks Received: 13
68
2013/11/05 - 17:51
validatus said
@Jgarciaillanf1
regards
Thank you validatus. The 4.1.2 firmware is the stock firmware, so: ¿should i do backup? If the answer is yes...
1- Install CWM.
2- Flash the ROM as DarthJabba explains.
3- Any issues probably xD
¿Is that correct?
Thank you again. :D
Wintermute
Forum Posts: 89
Thanks Received: 30
69
2013/11/05 - 18:12
1- Install CWM.
¿Is that correct?
Things may go wrong anytime and the odds are they will. It's handy to have a backup plan then. If you don't care about your current data, apps and setting skip to step 5.
1. Backup valuable data from internal sd to anwhere outside tablet.
2. Install CWM. Your ROM must be rooted first.
3. CWM: Backup NAND to external sd. That way you can possibly revert to your 4.1.2 if something goes wrong.
4. CWM: Install 20131029-kasty-rom-darthjabba zip.
If by chance installation succeded and tablet booted successfuly you're fine. Otherwise proceed like this:
5. Eject external sd.
6. Flash 20131029 Kasty ROM img using RKBatchTool (this will format your Android partitions including internal sd!). Boot it. It's rooted.
7. Install CWM using integrated Arctools (wohoo).
8. CWM: Install 20131029-kasty-rom-darthjabba zip from internal sd.
If installation succeded and tablet booted successfuly you're fine. Running factory-default Android.
 Otherwise try again or attempt to rollback to your 4.1.2 CWM backup. You may need to flash stock 4.1.2 before recovering 4.2.1 CWM backup in order to get suitable partition layout. Recover internal sd data from backup.
The following users say thank you to Wintermute for this useful post:
Jgarciaillanf1, Ohamn
kikeminchas
Forum Posts: 30
Thanks Received: 10
70
2013/11/05 - 21:19
Hi guys,
What is your battery consumption in stand by with DathJabba's latest? (no overclocked kernel). Mine rounds the 1% per hour on average... I have removed phone apk's. Tablet enters fine in deep sleep, no wakelocks. WIFI is off... I think this consumption is excessive but I somehow don't think I have a defect battery, it lasts around 5-6 hours navigating with WIFI on and around 7 hours reading comic books... what's your experience?
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
71
2013/11/05 - 21:37
Hello there, probably this is not the right place for it. But, here it goes:
Darthjabba, can you do some overclock tweak on the GPU ? When i´m reading ebooks the turn page is damm lag, basically. I saw on web a lot of things to overclock the MAIL 400 gpu that our tablet has, but none for it. Can you work something on that :X ?
Or this lag on turning the page (on ezPDF) is something else?
Thanks and sorry if this is the wrong place :X
Wintermute
Forum Posts: 89
Thanks Received: 30
72
2013/11/05 - 22:51
You may want to install kernel #38 OC that comes with overclock features (including GPU iirc).
A combination of Adobe Reader + 2D GPU Rendering enabled in Android developer settings provides the best known PDF viewing experience. At least in terms of rendering performance and scrolling smoothness. Night and day difference for me. Alternative PDF viewers like ezPDF are sluggish in comparison as they can't take full advantage of hardware assisted rendering (speculation).
DarthJabba
Forum Posts: 551
73
2013/11/05 - 22:53
Nope. I never did any overclock tweak on anything. I just packaged an overclocked kernel into CWM format.
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
74
2013/11/05 - 22:57
Im using the #38 kernel.. and i enabled the 2D GPU and the page turning option (like a book-with effects) is still lagged in ez :(
the turning page on Adobe is ugly.. thats why i wondered.. to bad im unlucky on this one..anyway, thanks for the quick reply.
Chuck Borris
Forum Posts: 20
Thanks Received: 7
75
2013/11/06 - 00:01
kikeminchas said
Hi guys,
Hy, i have overclocked version. Did the same things you did (phone.apk, wifi) and I have the same experience as you do. Power drain cca 1% per hour in stand by.
I think i'll have to go back to 07082013 darthjabbas version
3 Guest(s)
Devices in use: Desktop (3)
plovdiv
Dimon04
klabusterbomber
Esura
Radzio
jopeci
