2013/04/23
DominiqueL said
Âhttp://www.arctablet.com/users/forum/kasty_422_206_20131029_darthjabba_201310302102.zipÂ
kasty-cube_u30gt2-422-206_20131029-rooted4.zip (admin)
Darth, could you please tell me what are the difference between your rom and the one of admin?
apparently i had several return of people who installed the one from admin are experiencing freeze and so on...
Is there big differences that could explain it ? Or could it just be a question of wipecache,dalvik not done ?
tks
Read the changelog.
2013/05/15
JuLePe said
I installed the rom with stock kernel, and doing quite well, except for one problem in the lock screen, with the tablet switch vertical horizontal no reason. Would this happen to anyone else? Can it be because the previous rom was to Dukerth v2.03?
Thank you for all the work you doing.
Sorry for my English ...
Solved making wipe cache and factory reset.
2013/09/28
validatus said
HItablet switching horizontal vertical on lock screen
status bar disappearing after reboot
status bar notification bar blacking
this only when some modules are activated in xposed and I can't decide what modules
once xposed modules inactivated no more problem
regards
I think its Gravity box. I know you can modify 'table switching on lock' there.
The following users say thank you to Chuck Borris for this useful post:
jesmail, thatoneguysomeplace
2013/09/28
I sadly have to report ther is a major power drain on standby if the wifi is on.
Went from 100% to 90% in couple of hours.
After turning wifi of it went from 82% to 81% during the night (8 hours)
Darthjabba how can i achive that wifi would automaticaly turn of after locking (as is in most of your mods)
2013/06/06
Chuck Borris said
I sadly have to report ther is a major power drain on standby if the wifi is on.Went from 100% to 90% in couple of hours.
could you explain how did you manage it? i can't make wifi on after screen lock
2013/09/28
Chuck Borris said I sadly have to report ther is a major power drain on standby if the wifi is on. Went from 100% to 90% in couple of hours. After turning wifi of it went from 82% to 81% during the night (8 hours) Darthjabba how can i achive that wifi would automaticaly turn of after locking (as is in most of your mods)
could you explain
When i activate screen again in the morning, the first thing is, that i turn wifi on again... Nothing complicated...
2013/09/28
I might have spoken to soon... I'll retest this night... Â I'll report tomorrow...
2013/06/06
could you explain
i guess you have misunderstood me... i mean i couldn't make wifi "always on".. whatever i did wifi turns its off when screen sleeps
2013/07/09
sadness said
could you explain
Go to your settings-->wifi-->advance--> keep wifi on during sleep-->always. Thats how I have mine set up. If that does not work tell us what you tried.
Chuck Borris, thatoneguysomeplace
2013/04/26
Hi guys
I am totally confused regarding the stock kernel and the #38 O.C. version.
I thought that the latest 2.06 has had the kernel modified to improve battery use while asleep among other things SO if I put #38 O.C. kernel on my tablet then any improvements(?) from Cube official latest will be lost........or am I missing something?
On a totally different subject, the multi-window button is causing me annoyance. I need multi-window on (although I don't use it) to stop the back, home etc., soft keys flickering BUT when I untick the "show button" in settings it only stays "unticked" while the orientation stays the same. If I rotate the tablet it comes back on and the tick box is "ticked".
The question is, how do I make this option persistent through rotations?
Rob
Currently Online: antoniors021
62 Guest(s)
Devices in use: Desktop (53), Phone (10)
antoniors021
wemiy54158
sidor
houssmen
qarolus
dav512
