Cube v2.06 20131029 Kasty ROM - Darthjabba mod in CWM upgrade format
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
166
2014/01/20 - 14:29
Hi
verified
most of APKs run on multi windows
zoom, move runs also
we have to play with the multiwindows gadget
regards
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
167
2014/01/20 - 14:31
HI DJ
I updated dolphin
but after a reboot I have to re install it
regards
DarthJabba
Forum Posts: 551
Thanks Received: 396
168
2014/01/20 - 18:54
HI DJ I updated d
validatus said
HI DJ
I updated dolphin
regards
Sorry, but I don't understand that. I didn't have to reinstall it. It may want to update itself, but I wouldn't necessarily allow that, because it was a special version of Dolphin (patched, I believe, to run flash).
validatus
tamagnun
169
2014/01/24 - 20:38
Sorry, but with these fw the light sensor and microphone don't work (and in fact the voice recorder app hangs up and the autobrightness is always at minimum level), for example the app AndroSensor always report 10 lux and 0 db!
Do you think that my tablet has some hw problems? Same issues on your ones?
rafwallet
170
2014/01/28 - 13:38
hy guys,
i'm installed CWM recovery with ArcTools fixe with no problem and installed DarthJabbas rom 18 January 2014 – with overclocked kernel "T14" build, based on kernel #12 from 900supersport with no problem !
Antutu benchmark scores : >20000
very good tab ! and thks to Hongkongeek.com
Regards.
JimmyPage
171
2014/01/29 - 12:28
I can join the club ! My U30GT2 was delivered yesterday !!
After a full charge, I rooted it, and followed the instructions to install ArcTools and thus the CWM recovery package.
I then downloaded the v2.06 stock image (not overclocked) and followed the instructions in the initial post here.
Rebooted - everything was good.
Initial comments:
1) Why does *my* "Settings...Battery" screen only show how long the tablet has been on battery, and a list of apps and their consumption. My wifes bog-standard U30GT2 has a different screen showing time left on battery.
2) I like Chrome. Can I uninstall the "Browser" app ?
3) Miracast ? Can't see my tablet in my TVs menu. However I can see my TV in my tablets menu.
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
172
2014/01/30 - 10:01
@jimmypage
I tested about 800 apks without problems
also use appmonster for exemple
nova dolphin are quite good
chrome the problem is updating data from other systems
regards
JimmyPage
173
2014/01/31 - 18:40
Can anyone confirm if the light sensor is working under this version ? A quick run of a few test apps suggests that it's not :(
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
174
2014/01/31 - 18:52
@jimmyPage
yes it's ok
but the response time is not so short: 57 sec
regards
AnJaDo
175
2014/02/06 - 01:10
hello,
I have some questions on this matter:
1. what is the difference between 'overclocked kernel # 38' and '18 January 2014 - with the overclocked kernel "T14" build, based on kernel # 12 from 900supersport ' and which one is faster, better and stable?
2. do I need yet DJ_OC_kernels_20140118.zip if I have already installed kasty_422_206_20131029_darthjabba_cpu1800_gpu768_201401180918.zip?
3. in the folder 'DJ_OC_kernels_20140118' there are many 'kernel12-freaktab ...' and 'kernel-0027 ...' files. where is the difference? which one is correct?
4. which one is the T13 kernel?
5. I read 'This mod is set for 4GB data partition.' Is this automatically or do I have to set it manually?
many thanks and kind regards
AnJaDo
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
176
2014/02/07 - 18:40
hello,
1. what is the difference between 'overclocked kernel # 38' and '18 January 2014 – with the overclocked kernel "T14" build, based on kernel # 12 from 900supersport ' and which one is faster, better and stable?
Answer: "T14"
Answer: No not really. It just depends how you prefer to install roms.
3. in the folder 'DJ_OC_kernels_20140118' there are many 'kernel12-freaktab …' and 'kernel-0027 …' files. where is the difference? which one is correct?
Answer: Those were experimental at one point, and the product of Darth's helping us trying to find a fiting kernel to the last pre-kitkat rom. But hey if you still on pre-kitkat, feel free to follow the instruction and see if one of them fits you!
answer: look for "T13". I don;t think they were in that repository, though I could be wrong. I think there was a later thread on those. Feel free to look around though.
Answer: That is automatic. Enjoy!!
answer: Same to you!
Maikal
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
177
2014/02/08 - 10:55
hi
It's possible with "900 super sport" to chose 4, 6, 8 GB by choosing parameters file
is it possible to charge only parameter file from super sport after installing kasty or dj rom
this with rkandroidtool wiuth only parameter file choosed
regards
bk79
178
2014/02/09 - 07:40
hi, is it possible to add interactiveX and  smoothass governor? They should give better battery performance
ofers
179
2014/02/28 - 21:39
HI
i have installed the rom as you said in the first page of this topic
and the tablet is freeze on the welcome white screen after that i get the arc logo and thats it
what should i do now?
chamallows
180
2014/03/06 - 12:27
Hi, and thanks for your work. I tried your oc rom and it works fine.
I still have an issue (not due to your rom) with play store. I want install a game (the room two) but the tablet is'nt compatible (with samsung build.prop). I tried to modify the build.prop but my tablet won't start, i'm blocked at the bootsplatch animation.
Can you tel me how did you change the build.prop ? I know that this game for exemple works with my mk808 tv box.
thanks!
78 Guest(s)
Devices in use: Desktop (62), Phone (16)
jj3111
stoqn62
STOQN222
stoqn1958
Teksonroy01
clim
