Cube v2.06 20131029 Kasty ROM - Darthjabba mod in CWM upgrade format
katana1
136
2013/12/11 - 17:28
Now i have tested the tun.KO installer, it works fine.
Thanks for the Tipp.
jy_p
Forum Posts: 44
Thanks Received: 20
137
2013/12/11 - 17:41
Great!  Still, let me know if you find a way to make it permanent... If the script that you found works with this Tun.KO!!!
katana1
138
2013/12/12 - 14:05
I have tested the script, but it doesnt work.
I am looking for an other solution, if i have one i will post it here.
jy_p
Forum Posts: 44
Thanks Received: 20
139
2013/12/12 - 20:24
OK Thanks!
aydin2973
140
2013/12/14 - 15:15
I have a question for you guys my tablet where I've installed the ROM but then I saw that
* This mode is based on; kasty-cube_u30gt2-422-206_20131029-rooted4
but my version was 4.1
The tablet is not going to stay right on the opening screen
DarthJabba
Forum Posts: 551
Thanks Received: 396
141
2013/12/15 - 17:30
Is this a question or a report of a problem?
blade_
142
2013/12/27 - 20:35
hey,thanks for this rom!
how can i root first so i install cwm and after this,your rom?thanks
DarthJabba
Forum Posts: 551
143
2013/12/28 - 00:45
Install a Kasty ROM. You will find it already rooted.
aydin2973
144
2014/01/01 - 20:49
Hi I will setup this rom but my version is 4.1.1
Is it necessary 4.2.2 version to setup this rom?
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
145
2014/01/03 - 08:05
@aydin2973
There is two ways installing new "rom kernel" with kasty or DJ
1 with cwm with a kernel from DJ
2 with rockchip batch and a rom from kasty or DJ (restore)
I prefer the second way which clean the system
regards
2cold
146
2014/01/04 - 13:39
Problem
Skype incoming call have no sound
Also some minor Skype display problems
Problem seems to be related to Change #8
Tablet set to announce itself as GT-P7500 (Samsung Galaxy Tab 10.1)
Solution
Change /system/build.prop
ro.product.model=U30GT 2
ro.product.name=rk30sdk
ro.product.device=rk30sdk
ro.product.brand=CUBE
ro.product.board=rk30sdk
ro.product.manufacturer=rockchip
ro.build.product=rk30sdk
(take a look at orginal backup build.prop.orig)
Burs
Advanced Member
Forum Posts: 144
Thanks Received: 33
147
2014/01/04 - 13:55
Hi guys,
does this rom have dual resolution and/or multiple windows features?
Or are these features contained only in the official roms?
The tablet I bought recently should arrive in a couple of days, so I'm just planning my first steps...
Should I install this rom or wait for 4.4? I see some of you already installed KitKat, but I still find it too risky as it involves some additional steps and isn't tested thoroughly, and I don't want to break things on my first day. That is, if it doesn't arrive already broken, since many of you are having problems of all sorts :)
Thanks!
DarthJabba
Forum Posts: 551
148
2014/01/05 - 15:13
It has multi-window support. Whether the features works well or not is another matter. Personally, I don't use it. It (or, to put it differently, the kernel that I am currently running (i.e., kernel #27)) does not have dual resolution.
Burs
tamagnun
149
2014/01/08 - 19:00
I've received yesterday my Cube U30GT2, obviously it has the poor wifi issue (I'll open and modd it in next days...), but it seems to be OK elsewhere.
I'm ready to install this custom firmware, but I have a doubt: with this fw it will be able to use an USB 3G modem connected to the OTG port?
Someone has a list of supported USB 3G modem?
Thanks in advance for your help and attention.
Regards
junke17
150
2014/01/09 - 12:50
Thank you so much, that idea to create ROMs in CWM upgrade format is amazing. I just flashed yesterday this rom with stock kernel from Kasty and it works better than previous versions. Smile
Problem with poor wifi signal persist, but i think it is little bit better.
Problem with disconnecting wifi and connecting again is the same. I will try to change channel number of my router to 6, i read somewhere it may help.
regards
184 Guest(s)
Devices in use: Desktop (168), Phone (16)
elinajohn99
Heruth
tekan
GLUMAC40
firebenderyt
omar ifni
