2013/08/08
I have a U30GT2 with Kernel Version #38 Build V2.04 20130807. My Cube is not plugged in to any AC power when I tried updating to your version of 2.06.
Also, does anyone know how to backup to my EXT_SD using the CWM? It keeps on saying that my drive can not be found. I tried Mounting and formatting the drive while on CWM but nothing happens.
I don't like Titanium Pro because it doesn't always work and I'm having to install all of my apps when something goes wrong with the update.
2013/04/23
Perhaps this is a clue to the problem? I always have the AC power connected when installing from CWM.
Don't know anything about backing up via CWM.
2013/07/09
I would like to eliminate one variable if possible. For those who are having problems, can you please confirm that the tablet is actually connected to the mains power while you are installing the DarthJabba mods? Thanks.
AS I said in the other forum Darth, I bite the bullet and attempted a download to, and could not get past the arctool logo. TO answer your question I was plugged up to the same outlet strip that is also with my regular desktop pc and its screen, one lamp and a small desk fan (mini). THe strip is plugged into my wall outlet and nothing else.
Also, when I could not get passed it three times, I attempted to re-flash your overclocked mod again, which is what I had, and though I tried it two or three times just to make sure, waiting approx 10 mins between attempts, it also would not go past the archtool logo. So finally I had to do one of your previous mods 0807 or 0810, not sure right now but I think it was 0807, that took on first attempt, THEN I re-flashed your overclocked and that did it, reloaded like a champ! And you know, its even more alert than it was before! Less delay on apps and on loading from power-up. Still have to do that battery callibration on sleep though.
Hope that helps. Oh and Antutu scores have been between 19k and 20k, where before your overclock they had been like someone mentioned at least 1k to 1.5k lower. Of course it's overclocked now so I don't know it that means much.
2013/04/23
Thanks for the clarification; so the problem is not AC power or no AC power.
By the way, the kernel #38 overclock mod is just a kernel, not a full ROM. So if the ROM itself is broken, just installing the #38 kernel mods will not solve that problem.
2013/07/09
yoavst said
Mine stuck on arctablet logo, how can i restore?
Turn it off, then power back up by holding volume + and power button until it turns on, release power button, then at welcome screen, release the volume + button that should take you to the cwm r screen ands just reflash your previous rom from your sd card or wereever you flashed it too. Different variations on how to get to the cwm r screen.
For me I hold the volume+ then press the power up button for a sec or two and relase it while still holding volume+. I don't release the volume until a few secs of the welcome scrren and that takes me straight to the cwm r screen.
69 Guest(s)
Devices in use: Desktop (60), Phone (9)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
