2013/07/09
kikeminchas said
Maikal, what is your battery consumption in Stand By? I guess you're using the overcloked one, right?Â
Thanks.
Yes using overcloked, but I had not done a calibration yet on standby, so all I can tell you is that after originally downloading the overclocked version and before going to bed, and not calibrating the battery; I did leave the tablet fluuly charged, on standby, and when next morning it still was on 99%. It was also before loading phone apps also. I will run a standby test overnight on the battery.
2013/04/26
maikal said
Thanks.Â
That sounds nice. As soon as "admin" make a CWM installation throw arktools, i will give it a try
For some reason, CWM image doesn´t install as it should for me
2013/07/09
2013/06/15
@maikal
I dowload all the modules from xposed site
I install them all
The most interesting for are those I report:
Advanced Power Menu
Android Tuner (module more interesting than the apk)
App Setting
Boot Manager
Master Key Dual Fix (you know it)
Play Store Fixes
GreenBatteryCXircle (works also in standby mode)
They run correctly on my CUBE
regards
The following users say thank you to validatus for this useful post:
maikal
2013/07/09
validatus said
@maikalÂ
I install them all
Advanced Power Menu
App Setting
Boot Manager
Play Store Fixes
regards
Yes, I just updated my Xposed last night and most showed up as part of the update. I just glanced through it because my bootmanager would not install until I updated it. It also updated Gravitybox. I will check later to see if the update brought those others into the installer. Thanks!
2013/04/23
From what I could see, I couldn't tell any difference with respect to battery usage - but then I never had battery problems.
The overclocked kernel generates Antutu scores about 1,000 higher than the standard kernels.
sadness, OhamnDarth Jabba, the Dark Jedi from Nal Hutta
2013/07/09
Yes, my antutu scores have ranged from a low 19.500k + to a high of 20k+ over 6 test since flashing the 38kernel Darthjabba mod. I still have not gotten around to do a real battery calibration because I have been busy playing with Garvitybox and greenefy and some others that I had not played with before. In any case however I have not noticed previous problems. It is causing some freezes, not many, and slow app openings, nothing I can't live with yet.
I do have phone apk, and running overclocked version for now. I will test non-overclocked version, and remove phone apks from each to test their battery and handling. Again, over the next few days, the wife is complaining I'm ignoring her more than usual...;-) lol
2013/04/16
2013/04/23
Bsoft2007 said
Does anyone know if i can apply this Kernel on Kasty 2.06? Is it compatible
Currently Online: migfafe
83 Guest(s)
Devices in use: Desktop (67), Phone (16), Tablet (1)
Kaydc__
jessicapeterson
Riki111
andre92
firmwarefile
mongol
