2013/04/26
2013/01/01
DarthJabba said
B. Overclocked Kernel #38:
http://www.arctablet.com/users/forum/kernel38_overclocked_darthjabba_201310171913.zip
Good day all , I address to DarthJabba, not good to steal other people's work and pass them off as their own !You are not the author overclocked kernel # 0038 for U30GT2, you just simply pilfer it in my firmware , you should at least when trying to post it at least made ​​reference to the author , or do you think I am not here and not what does not keep track , you're wrong ?
Now about that in this nucleus dispersed , changed a table of frequencies of the GPU, increased frequency of DDR3 528MHz to 667MHz , increased the maximum CPU frequency up to 1,8 GHZ and reduced the minimum frequency from 312 to 126MHZ and reduced operating voltage up to 0.8 Vps Sorry for my bad English!
2013/04/23
ImaSoft said
http://www.arctablet.com/users/forum/kernel38_overclocked_darthjabba_201310171913.zipGood day all , I address to DarthJabba, not good to steal other people's work and pass them off as their own !You are not the author overclocked kernel # 0038 for U30GT2, you just simply pilfer it in my firmware , you should at least when trying to post it at least made ​​reference to the author , or do you think I am not here and not what does not keep track , you're wrong ?
Wow! Very strong words indeed! - "steal", "pilfer", "pass off", etc.
Can someone with some decency and a brain please ask this false accuser where I said that I created these kernels? Please check out your facts before making defamatory allegations. What is wrong with you?
Someone in this forum found the kernels in a Russian forum ("FLASHER_v2.12_ADB_FOR_U30GT2"), and wondered whether they could be used with the Kasty ROMs. I said PUBLICLY in these forums that, if he made them available for download, I could create CWM update zip mods for them. All I do is create mods in CWM update zip format for people to install things easily.
I am sure that it is too much to expect an apology from those who feel free to make unfounded accusations in the public space. So I won't hold your errors against you.
2013/01/01
Wow! Very strong words indeed! – "steal", "pilfer", "pass off", etc.
I relied on the fact that the changes I made in kotoryya # 0035 and # 0038 core were absolutely identical to what you posted # 0038, the probability that you would make too changes are very small so I changed the CPU voltage table for themselves, dubbed frequency a GPU that you would not have made ​​the palatine for what it is ... or do you just assembled, I did also identical!
2013/04/23
You are happy to make false accusations publicly on the basis of your guesswork? Wonders will never cease! In case you have any bit of interest in the actual facts (as opposed to whatever happens to come into your head), then read this thread:
validatusDarth Jabba, the Dark Jedi from Nal Hutta
2013/06/05
Imasoft commented above that the Overclocked kernel has the minimum speed set to 125Mhz (instead of 325Mhz) and a reduced Voltage. This will of course contribute to a better battery life. I don't know if the not overclocked kernel has this 2 changes as well... I also installed the overclocked one so I can't confirm this...
Run some stability test if you install the overclocked one, it seems the additional speed and the settings above are causing troubles to some users (freezes, unresponsiveness...)
Working great with Kasty's ROM Imasoft, thanks!
The following users say thank you to kikeminchas for this useful post:
validatus
2013/04/23
The overclocked kernel worked okay for me (Antutu score of 19500). But I changed it back to the stock #38, as I am still concerned about the higher clock frequencies.
OhamnDarth Jabba, the Dark Jedi from Nal Hutta
2013/07/09
The overclocked also worked for me. Last night I added your phone mod to see what happens. I am runing a battery callibration now.
Update:
With DarthJabba's new #38 special I am not having any major battery drain to speak off so far. Last night I plugged in the old telephone apps. Again not noticing any major drains, but Gsmart battery Monitor was reporting the phone apps taking a major bite of the battery power, but that might not translate to "Major" battery usage, just that it's still using the most of what every other parts of the system is using. I am doing a battery re-callibration all over again because I fear ...tampering.. I think my wife or my son took the tablet for a ride on the web yesterday...lol, so I will report on it later.
But I did download Dead Effect game yesterday and played for about 10mins. Battery was running hot over at least half the back. You could feel it over the cover I have over the tablet. I have felt it before with the only other game I have on my Cube, GOF2-HD and I might add with every other rom I have installed since I arrived here on this forum. Since I am not an "often" game player by any means I am not sure if thats normal or good/bad at all for the tablet. If any one can chime in on that I'd appreciate the lesson.Â
80 Guest(s)
Devices in use: Desktop (66), Phone (14)
lbalexa001
rkg2303
sergey-tax
houseofcandy
duviauxi
benevento89
