2013/04/23
Wintermute said
I have attempted to remove Dolphin Browser packed with this ROM so I could install recent beta and updates. Deleted both app and data no problem.For some reason Dolphin Browser can't be installed from Google Play anymore. App installer keeps failing on weird error "Incompatible with other application using the same shared user id". Ouch.
In the next release of the mod, I will move Dolphin to the data partition.
maikal, csjanne, Chuck BorrisDarth Jabba, the Dark Jedi from Nal Hutta
2013/09/15
Ohamn said
Good evening all!I have tried to inststall CWM without  succeding.
I want to try this CWM version Rom.
Can you please help me with CWM installation files and easy to follow
Instructions I would be forever thank full!
The "stock" custom ROM I'm running now is a battery hog.
Thanks in advance!
// ohamn
Just copy the Zip file, don't unzip it
The following users say thank you to Segarra for this useful post:
Ohamn
2013/04/23
rzamoras said
Hi, has anyone tried the multi-user? Â For me it isn't work, the tablet restarts and then dials Android error on the new user.. "se ha detenido la aplicaciĂłn com.android.provision"....Â
Indeed, it is extremely flaky (both on 20130807 and 20130810). I haven't been able to get it to work on either of them, without spontaneous reboots. It used to work on earlier versions.
2013/09/28
I am new to android world, so..everything is new to me Â
Thank you for tips: validatus and darthjabba.
Maikal - i tried to point out, that es file exporer you mentioned is cool app Â
And somewhere i read, you can manualy copy apks from system to data with es file explorer.
But....i think i'll stick to darthjabbas advice not to do so.
Looking forward for new release Â
2013/07/09
Chuck Borris said
I am new to android world, so..everything is new to meÂ
No worries Chuck, I was hoping I had not been drinking 'n advising again!...it used to be a problem lol
2013/07/09
DarthJabba said
rzamoras said
Hi, has anyone tried the multi-user? Â For me it isn't work, the tablet restarts and then dials Android error on the new user.. "se ha detenido la aplicaciĂłn com.android.provision"....ÂIndeed, it is extremely flaky (both on 20130807 and 20130810). I haven't been able to get it to work on either of them, without spontaneous reboots. It used to work on earlier versions.
 Mine is working fine, in both modes. Just tried it.
2013/09/11
"I have uploaded the Darthjabba mod of 20130807 mod. You can get it here: http://www.arctablet.com/users/forum/kastycube_u30gt2422204_20130807_rooted_darthjabba_201310032215.zip * This mod is based on; kasty-cube_u30gt2-422-204_20130807_rooted *"
Hi Darthjabba!
I just wanted to thank you for your great ROM!
My stock ROM crashed my tablet a couple of times a day.
The keyboard was nothing but crap!
With your CWM enabled ROM I haven't seen one crash yet.
The stock keyboard works just fine.
No Chinese crap apps'
I reached 18152 in AnTuTu.
So I'm really happy as you can understand!
Really interesting to follow you and seer where your ROM will take us all!
Can't wait for your first 4.3 ROM!!
// Ohamn
2013/10/14
Hi DarthJabba (and all )
Installed the mod (above the final 2.04: (CWM recovery)Â kasty-cube_u30gt2-422-204_20130810-cwm_rooted4d.zip) - everything's OK, except the second reboot (the first one made with reboot app included in this ROM) - it hanged the device on logo. turned it off with "Vol-" + "Power", booted and then it works great. Data partition is still 2 GB (although the above kasty's ROM failed to install CWM correctly, I did it in other way).
Many thanks to DarthJabba!
Battery consumption shows 0% battery loss in sleep mode (against 20% in 4 hours on original Kasty's kasty-cube_u30gt2-422-204_20130810-cwm_rooted4d.zip), not sure how it's in real. Will test a few more days.
Got a question about battery calibration: if I started calibration and then rebooted the tablet several times (not connecting it to charger) - is it OK, or I should fully discharge the tablet without rebooting it for clear stats?
58 Guest(s)
Devices in use: Desktop (50), Phone (8)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
