2013/07/09
Okay. So last night, after leaving here at 4pm, and the tablet having recorded 0% loss of power, I did not turned it off, left it asleep.stand by. I turned it on at about 9:30ish 10:pm to do some reading. Tablet was still at 100%, though CS battery monitor stated 99%. I read until about 11:30ish. I was surprised to see a 21% loss in such a short time!
I did turn on the wifi during that time. Wifi and screen, and App ussage activity were the biggest hogs at 67% and 1.1%, App usage at 30%( ANdroid System 10.9%, Google services 4.9%, Transparent Weather clock 3.2%, Kernel(android os) 2.7%. WIth Amazon (kindle), Nova Launcher, Hangouts and Avast taking a 1.4 to 1% of the App Ussage %tage)
Wifi was on for 1hr:24mins:29sec
Screen was on 1hr:31mins:42sec.- 37% of time on dim, 63% on medium. Going to have to watch that.
Thats my report for now. I will continue to leave it on standby today and see were it will take me with this charge. Right now it's on standby with no wifi. Seems any sort of communication usage or activity will take a nice chunk of power, which of course its to be expected, that and just plain leaving the screen on to show off how pretty our screens are to other people we would like to show off to, as they apss by our stations. lol
I'd like to hear more from others!
2013/04/23
@maikal - I think you have a post-calibration issue, and some of the battery stats are probably off. After calibration, you have to run the tablet until the battery is completely empty - e.g., by non-stop youtube videos for hours. When the battery is empty, the tablet will turn itself off. Turn it on again, and you might find that there is still life left - keep running stuff until it switches off again. Then recharge the battery to full. After this, you should get correct battery readings.
maikal, Chuck Borris, OhamnDarth Jabba, the Dark Jedi from Nal Hutta
2013/07/09
Righto sir. I will try it again. Figured something might be off. I figured someone would point it out. The rom however is working smoothly as so far everyone else is saying. It actually has not run dry from first callibration after installing your rom. Since I had it on stand-by mostly. So I am turning it awake now to finish off that charge. Will report back. At least I'll ne able to hear some music...lol
2013/04/23
robiom said
Thanks for your hard work DarthJabba. Quick question, I have the "final, 0810" version which has only 2GB data partition. Can I use this update.zip (via CWM) as it has a 4GB data partition?
Rob
Not sure. The mod itself installs very little data, because it mostly leaves your data partition intact. Possibly if your data partition has at least 50mb free space, it might not be an issue at all - but I cannot guarantee anything.
2013/09/28
@maikal I disable those apps in: system-->apps-->all apps--> I clicked on the app and then button disable.. nothing else...
@validatus thank you for this app "system/app mover" it has realy cool description, that explains/opinions-on-teclast-p90hdaches me some new things I'll definitely give it a try
@DartJabba thank you about calibrating isues, I have same experience/problems as maikal
@robiom I installed this Mod throug final 0810 CWM version (because 0807 version doesnt have CWM - or at least i didn't find it...) and i have 4 gb of internal storage and 26 gb of nand flash now
- or would it be better to take some other CWM version as a basic?
The following users say thank you to Chuck Borris for this useful post:
maikal
2013/07/09
2013/07/09
2013/09/28
DaethJabba, i would like to ask, which app would you recomend,
To move apps from system to data and from data to system?
The app that validatus recomended needs bussybox.
Maikal sugested es file explorer, and i read that i can just cut/paste apk from
One folder to another. But there seems to be a trick about moving the right lib along with apk..
Any advice from you would be most welcome.
2013/04/23
Chuck Borris said
DaethJabba, i would like to ask, which app would you recomend,To move apps from system to data and from data to system?
I don't know anything about moving libs, and I would not recommend moving them at all. I also would not recommend moving things from system to data, unless you are absolutely certain that the system will not be rendered unusable. The best way I know of moving stuff is with Titanium Backup. The registration fee is more than worth its weight in gold.
2013/07/09
Mmmm... I think you mixed me up with someone else Chuck. I am not that advance in the knowledge to make such a suggestion. I have moved apps from system to ext sd card by copying them with ES, then deleting them from system, then later moving them back to test battery consumption, but that was the phone apps only, during the first Darth Jabba rom. That worked for me.
2013/09/05
I have attempted to remove Dolphin Browser packed with this ROM so I could install recent beta and updates. Deleted both app and data no problem.
For some reason Dolphin Browser can't be installed from Google Play anymore. App installer keeps failing on weird error "Incompatible with other application using the same shared user id". Ouch.
2013/09/11
Good evening all!
I have tried to inststall CWM without succeding.
I want to try this CWM version Rom.
Can you please help me with CWM installation files and easy to follow
Instructions I would be forever thank full!
The "stock" custom ROM I'm running now is a battery hog.
Thanks in advance!
// ohamn
58 Guest(s)
Devices in use: Desktop (49), Phone (9)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
