2013/04/23
I have uploaded the Darthjabba mod of 20130807 mod. You can get it here:
* This mod is based on; kasty-cube_u30gt2-422-204_20130807_rooted
* This mod is set for 4GB data partition.
CHANGES to the Kasty ROM:
1. The Phone stuff has been removed
2. Some unnecessary library files (relics from removed Chinese apps) have been deleted.
3. Multi-user mode is enabled by default (fw.max_users=5)
4. Some extra apps added to system folder (Dolphin browser, Reboot)
5. Some extra user apps added (e.g., Bitdefender Antivirus, Master Key dual fix, Nova Launcher, Bluebox security scanner, etc.)
6. persist.sys.ui.hw set to "false" (allows some games to play)
7. ro.rk.systembar.tabletUI set to "true" (solves wallpaper stretch problems)
8. Timezone set to London
9. Language/locale set to GB and English
10. Tablet set to announce itself as GT-P7500 (Samsung Galaxy Tab 10.1) - this is for better compatibility with Google Play apps
Installation:
0. Eject and remove any external SD card
1. Copy this zip file to the tablet's internal SD card (i.e., NAND)
2. Reboot the tablet to CWM Recovery
3. Select "Install zip from sdcard"
4. Then select "Choose zip from sdcard"
5. Scroll on the SD card to this zip file, and select it
6. Confirm that you do want to install it; the installation process will take several minutes.
7. The tablet will reboot back to the CWM Recovery
8. Select "Reboot system now"
9. Go and make a cup of tea and sandwich.
10. Drink the cup of tea and eat the sandwich; make sure you spend at least 10 minutes doing this.
11. Come back to the tablet after 10 minutes. Everything should be ready now.
NOTES:
A. You may need to reboot the tablet once or twice for things to settle down completely (it happened to me).
B. You might get Maps force-closing once or twice (it happened to me)
DISCLAIMER:
You use this mod entirely at your own risk! If your tablet is bricked, then that is too sad.
If you are worried about bricking your tablet, then STOP RIGHT NOW !!!
admin, validatus, sipdude, JunglBell, UserM, maikal, kostasaerakis, Uznamer, khmra, robiom, Wintermute, Ohamn, Reywind, fiji, itspecht, DaezDDarth Jabba, the Dark Jedi from Nal Hutta
2013/05/01
installed the firmware works fine. While I can not say about the battery because little worked. But noticed that the stock browser does not support online videos from YouTube , "you should install the latest flash player". In the rest until all OK. I Will continue testing. Thanks DarthJabba!
2013/04/23
validatus said
HelloWhy this "10. Tablet set to announce itself as GT-P7500 (Samsung Galaxy Tab 10.1)"
Perhaps it is possible to modify this in build.prop
Yes, you can modify it in build.prop
validatusDarth Jabba, the Dark Jedi from Nal Hutta
2013/04/23
JunglBell said
per hour of sleep with the included wifi tablet discharged by 3% , it can be assumed that for 33 hours, he discharged on 100% , I think it's not a bad result.
That's not a good result. After 12 hours, mine has only lost 15% of the battery - and this includes reading for about 20 minutes, running Antutu benchmarks, and some other small apps. A full battery on standby alone should last about 5 days.
2013/04/23
fana75 said
hiCould you, please, create a version that could be use with rockchip tool?
What are the main difference compare to 2013/08/10 which is more recent?
Regards
If you want one that can be used with the Rockchip tool, then you need the original Kasty ROM.
2013/05/01
DarthJabba said
JunglBell said
per hour of sleep with the included wifi tablet discharged by 3% , it can be assumed that for 33 hours, he discharged on 100% , I think it's not a bad result.That's not a good result.
but I have wifi ON .in any case, the work in the Internet is very slow , YouTube browsers running in full screen mode is not correct,websites like Facebook very slow down,especially when writing text
Currently Online: vonkarayan, astosenix
76 Guest(s)
Devices in use: Desktop (67), Phone (11)
grielgryel
klaus1255
neverever007
favorit
Альфвоф
kevbez
