Cube U30GT2 Widgets not in list until reboot
Ulster94
Thanks Received: 4
2013/07/09 - 22:03
Hi guys,
since firmware 2.x I have the problem, that all widget which will be installed are not selectable from the widget list until the next reboot.
This problem does not depend on the launcher and is not influenced by the SD card (whether a widget is installed there or not). I already reset my launcher to stock (hint found by google search) but no change.
Today I installed the lastest 2.04 test ROM but the same issue appears as well.
Any hints or comments to check ?
Thanks.
77 Guest(s)
Devices in use: Desktop (67), Phone (10)
cutierogue
