Cube U30GT2 rk903 wifi chipset stability / issues
Hady
2013/05/28 - 21:41
I am wondering if anyone is having issues with the wifi signal/connectivity
The signal is quite poor and fluctuates if I move away from the router. It disconnects often if i'm 15 meters away from the router. The speed fluctuates from 65mbps to 1 mpbs depending on how far I am from the router.
I did try to change signal and frequency => same result.
I am running 4.2.2 (had the same result with 4.1)
Is there any trick that can improve the signal? or flash the chipset with a more recent version? Or wait for a newer android version...
Thanks!
Currently Online: VMILCINOV
68 Guest(s)
Devices in use: Desktop (65), Phone (4)
VMILCINOV
