Cube U30GT2 KitKat 4.4.2 20140606 Kasty-Funrom ROM - Darthjabba mod in CWM upgrade format
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
31
2014/06/29 - 17:28
The problem for me, and why I remain on your previous rom, is that Oma's original rom had problems, he then fixed one problem by posting the fix, then the next issue was also posted as a fix. I'm not that tech savvy to go in and flash each fix in the manner he explained and I'm afraid if inputting a fix in the wrong place since I have never dealt into opening a rom in order to make fixes. Had he posted a completed rom with all the fixes as you often do I would jump into my guinea pig outfit and flash it, then report on it. I have neither tried the newest kasty since the problems were posted even before I had time to flash it nor the Oma rom due to the same reason and subsequent piece-meal fixes. I wholeheartedly appreciate their efforts, but like I said I am just not sure enough of my abilities to go beyond a simple flash of a fix as in your rom builds. I just don't have that kind of time right now, between my two jobs and giving the wife her time. Which reminds me ...lol... here she is again about the vegy garden! Have a good day and thanks for looking into this. I'll check in during the day to see what's happening.
bond.bg
DarthJabba
Forum Posts: 551
Thanks Received: 396
32
2014/06/29 - 20:02
The CWM package I released has all the Oma fixes.
maikal
Forum Posts: 394
Thanks Received: 51
33
2014/06/29 - 22:33
Yeah I know, that's what I appreciate about yours, simple package.
diwill
34
2014/07/07 - 11:39
How about Overlock?:)
olowokandi
35
2014/10/06 - 18:17
Hi, as mentioned by someone before, I too notice that SuperSU does not work when i first run my tablet with this ROM.  Anyway, I manage to root it with some helps from third party software (wmshua, a chinese apps) , and then re-install the SuperSU, everything work fine now.
I was on 4.2.2 before (DarthJabba's version), failed to upgrade directly using CMW.  System just won't get thru the first cube logo for more than 15mins of waiting. End up I have to flashed our admin's 4.4.2 version (Funrom_Studio firmware dated 2014/06/06) using Rockchip batch tool 1.7 (becareful with the USB3.0 issue!), flash CWM using arctools, finally this ROM, and re-rooted.
I am a happy man now with my tablet rejuvenated!  Big thank you to our admin, Oma and DarthJabba!
Mark06
Forum Posts: 222
Thanks Received: 41
36
2014/11/02 - 11:51
Yep that chinese app works, me glad to now. You have to install the adb drivers and then take the second root option.
Cube u30gt2 tab
dmcp
37
2014/11/06 - 00:38
Hi everyone
I downloaded this DarthJaba rom yesterday and when I flash it into my Cube u30gt2 it got stuck on the Cube chinese logo after the reboot. I waited for 40 minutes (just in case) and nothing happened.
Tomorrow I'll have to try the suggestions by olowokandi
Cheers
DMCP
The following users say thank you to dmcp for this useful post:
maikal
maikal
Forum Posts: 394
Thanks Received: 51
38
2014/11/06 - 03:13
let me know how that worked out. If you have time, the steps to each step would be nice. and location of Chinese app you used, tools etc. I would like to give it a shot now that I have new battery installed.
79 Guest(s)
Devices in use: Desktop (75), Phone (4)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
