2013/04/23
Ok, here's the DarthJabba CWM format of the Kasty-Funrom ROM for Cube U30GT2 KitKat 4.4.2 (20140606).
It incorporates the fixes posted by Oma.
Disclaimer: This is untested. Use at your own risk.
Download:
Wintermute, Uznamer, maikal, rudydj, ghiruxDarth Jabba, the Dark Jedi from Nal Hutta
2013/04/23
musico59 said
Thanks !!!Is it possible to have a RKbatchtool version of this room like admin do ?
You already have it - the original ROM released by admin (a.k.a Kasty). Therefore, you don't need this one.
CWM packages are installed from CWM or TWRP recovery, not with any other tool. Your user apps and settings will be preserved. It is a good way to try new ROMs without having to reinstall your user apps or have to reconfigure your user settings afterwards ...
maikalDarth Jabba, the Dark Jedi from Nal Hutta
2013/07/09
2013/07/09
2013/04/23
maikal said
Root is not something included in these roms, you have to root the tablet first then install the cwm and afterwards the rom.
If the ROM is not rooted, then installing it will supersede all the above. So the question reamins whether the original Kasty. Normally, Kasty ROMs are rooted - but perhaps something went awry with this one?
2013/07/09
2013/07/09
60 Guest(s)
Devices in use: Desktop (50), Phone (10)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
