2013/04/01
I have two cube u30gt2 tablets and have a problem with one of them with bluetooth.
one of the two tablets can not find my av receiver (Pioneer VSX-827) with bluetooth module (Pioneer AS-BT200), but the other tablet has no problems with it.
both tablets finds other devices without problems, for example my smartphone or the other cube tablet.
Both tablets are identical with android 4.2.2 v2.03
Here are the serial numbers of the two tablets:
tablet A => u30gt2w32gbw13120191851 (tablet with problems)
tablet B => u30gt2w32gbw13172670597 (the tablet without problems)
also tablet A can't find a PlayStation 3 Controller with the sixaxis controller app by bluetooth, but tablet B works fine.
I hope you can help me?
best regards
Andy from germany
2013/06/19
I've had same cube for 2 days and have Pioneer vsx1120 so it may be different for you but Pioneer needed to be "paired" so I went to home setup, system setup then "other setup". The BT pairing was the last option and it allows you to choose a pairing code. Then I hit ok to start the pairing. I switched the cubes BT on and it does its search and it picked it up. As to the performance it was a different situation. Music was cut up and choppy as signal was being cut. I shut off the WiFi and it was better but still had problems when tablet was being moved around. I was within 10 ft (3m) of the Pioneer at all times. I am thinking of removing the aluminum strip around tablet (see the post just before yours) to see if that would help or going in deeper for the antennae fix. Maybe someone could tell me if bluetooth is also using the same WiFi antennae?
132 Guest(s)
Devices in use: Desktop (128), Phone (4)
