Cube U30GT2 Android 4.4.2 KitKat new rom???
I found a ROM from 14.10.2014
Mark06
Forum Posts: 222
Thanks Received: 41
61
2015/03/11 - 11:54
maikal said
Has anyone tried this rom from freaktab.com?
http://www.freaktab.com/showthread.php?21374-U30GT2-Custom-KitKat-ROM&p=284356#post284356
Dated 12/31/14
Maikal, the download link doesn't work.
Cube u30gt2 tab
edgertop
62
2015/03/11 - 17:23
Link for the development rom has been removed you need to click on the release version link on the message below
Release version
cxdani
63
2015/03/11 - 20:47
I flashed this rom on my cube.
It came up in chinese, and somehow I managed to change the language.
I just rooted the tablet.
There is an application, an icon with an R on a green background. Does anyone knows what is that. It looks that is doing something with permissions. And itself has all permissions. I will try to freeze it with TitaniumBackup.
The apps partition is only 2G, compared to 7G that I had before.
Let's hope that the handy guys will take this rom and will change it a little bit.
edgertop
64
2015/03/11 - 21:05
sounds a bit like the kinguser root app
Mark06
Forum Posts: 222
Thanks Received: 41
65
2015/03/12 - 11:10
there's an app for removing startup/system apps, it's called "root app delete". The tab you use has to be rooted.
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
66
2015/03/12 - 19:49
lenniss said
Rooted the tablet with the chinese program and fixed the mobile phone battery drain by moving these packages by hand with es filebrowser.
These are the apps that are moved:
/system/app/Email.apk    x
/system/app/Exchange2.apkx
/system/app/GoogleTTS.apk
/system/app/Launcher3.apkx
/system/app/MediaUploader.apkx
/system/app/PrintSpooler.apkx
/system/app/RKUpdateService.apkx
/system/app/Stk.apkx
/system/app/TelephonyProvider.apkx
/system/app/VoiceSearchStub.apk
/system/app/WAPPushManager.apk
/system/priv-app/talkback.apk
/system/priv-app/Mms.apkx
/system/priv-app/MusicFX.apkx
/system/priv-app/TeleService.apk
This is from DJ phone remove zip readme.
My tablet lasts 3-4 days in standby with wifi off. Overclocked version.
You can use an app called "root app remover" (needs root), to remove those apps named by lennis. 4 days is possible but only if you don't use it much i guess. Can't get mobile/phone completely gone from battery stats though. Further a reboot after removing stresstest.apk doesn't take any battery power anymore. That's what i found out. Guess every startup stresstest.apk is run to test the device costing a lot of battery power.
Cube u30gt2 tab
cxdani
67
2015/03/12 - 19:50
I removed some things from the tablet, it looks ok now.
The only problem that I have is that on the lock screen is showing the temperature for ShenZhen.
Anyone managed to change this, or to remove the widget?
nelySLB
Forum Posts: 34
68
2015/03/12 - 23:42
Release version
Hi i havê installed this but mi tablet stays on u30gt2 boot logo
Mark06
Forum Posts: 222
Thanks Received: 41
69
2015/03/13 - 01:27
Yes, remove the logonscreen, disable the wiping in settings.
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
70
2015/03/13 - 06:03
Seems pico.tts was the last app for the phone. Removing it also removed the phone stats.
Cube u30gt2 tab
lenniss
71
2015/03/13 - 09:59
I removed all apps in the list but I couldn´t find all of them.
If I go in battery stat I don´t see the mobile phone in the battery drain list.
Edit: I didn´t remove the apps just moved them to app-backup like the DJ-zip file does.
Mark06
Forum Posts: 222
Thanks Received: 41
72
2015/03/13 - 17:01
multicore cpu free gives you the possibility to turn of 2 or 3 from all cores, so you can save even more energy when not gaming.
Cube u30gt2 tab
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
73
2015/03/15 - 04:22
So can we get a report on how the rom is working out? How did u root it and how is the tablet working for you?
maikal
Forum Posts: 394
Thanks Received: 51
74
2015/03/18 - 03:25
nelySLB said
Release version
I saw that complaint on the Freaktab thread page. But there is no response yet for it.
maikal
Forum Posts: 394
Thanks Received: 51
75
2015/03/18 - 03:27
What did you remove? How/what process did you use to flash it? tell us more.
Was your Cube already rooted when you flashed the rom of did the rom contain root and recovery?
59 Guest(s)
Devices in use: Desktop (51), Phone (8)
rk.13
siwinfi64
dangphat
dpc
ngu
