Cube U30GT2 Android 4.4.2 KitKat new rom???
I found a ROM from 14.10.2014
Mark06
Forum Posts: 222
Thanks Received: 41
46
2014/11/26 - 16:30
is there a solution for the tablet's speakers that keep working while the hdmi is connected too? I mean i want to listen by the speakers of my stereo through hdmi. Now i have like a 3.5 inch headphone plug connected to the headphone connector and no headphone connected.
Cube u30gt2 tab
EzerchE
Forum Posts: 12
47
2014/12/08 - 22:31
put a headphone jack :) i solve the problem by that way
Mark06
Forum Posts: 222
Thanks Received: 41
48
2014/12/15 - 17:10
You can also put 0 instead of 360 degrees in build.prop editor. When you overclock to 1.8 ghz. Has the same effect.
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
49
2014/12/15 - 17:49
how come you guys get antutu scores on to 23000 while i get like 26000 ?
Cube u30gt2 tab
edgertop
50
2014/12/15 - 19:27
Lots of things can skew an antutu score to make it look faster or slower, for example the speed of the external SD. I suspect its more important how the ROM feels with this sort of difference. If your getting 26000 your doing well but 23000 is none to shabby as well on this tablet.
Mark06
Forum Posts: 222
Thanks Received: 41
51
2014/12/20 - 19:37
hello,
to make the system energy efficient i installed the following apps:
- DU battery
-battery saver pro from the makers of antutu set to level 4
-screen time out 15 secs
-volume off
-100 to 92 percent within about 11 hours time
-installed the phone disable apk form DJ with cwm
-email check every 15 mins
-wifi put off when screen is off
-install nova launcher speed as lightning
-set developer scales to 0/off
-build prop editor rotation to 0
Cube u30gt2 tab
kykif
Forum Posts: 15
52
2015/01/05 - 12:46
Mr.Nice said
Hallo,
I have found this ROM, but I can not find out if this is a new from 51Cube.
Forum link: http://bbs.51cube.com/forum.php?mod=viewthread&tid=97337&highlight=u30gt2
Download link: http://pan.baidu.com/s/1mgNwnhu
I'm not so good at Chinese :)
My question,
Is there anyone who can see if this ROM will work and be stable.
I look forward to some feedback.
hello all,
I just tried this rom on my tablet. You can find it here :
https://mega.co.nz/#!OgNxDBIS!bSsaPzYEC8DLzfiZmLneCYuObCWq9BFvXm1wodbjm2c
it's very fluid, stable and fast.
I fail to root this rom. Can a person of the staff could try to make a rom rooted without the chinese root apllication (don't work)?
Thank you in advance for your help and sorry for my english...
Have a nice day !
Mr.Nice
53
2015/01/05 - 13:43
Hi Kykif
On page 2, a link to a program ;-)
And it Works... I used it to root my tablet.
"Copy/paste - page 2"
Rooting: install adb drivers: http://www.adbdriver.com
install root tool: http://download.wmshua.com/WMShuaSetup.exe
connect the tab, let the wmshua program fine out you’ve got a cube, then go to tab root/unroot and select down the second root option on the right. This might take some time. If is good the percentage drops from about 97 back to 90 for three times(three tryings to get it done), then it shows rooted and reboots the device. This is how i got my (overclocked) chinese 29102014 rom rooted.
kykif
Forum Posts: 15
54
2015/01/05 - 18:06
Hi Mister Nice,
I had not seen! lol
It works the first time thank you so much !
The overclocked rom is better or not ?
lenniss
55
2015/02/24 - 10:07
I´ve used the 4.4.2 from June earlier with some gpu tearing when HW overlay is disable.
This rom is as fast and even faster then june with overclock kernel. I´m using the one in the first
post in this thread. As somebody said before this ROM finally makes this tablet good as i should have been
from the beginning.
Thanks for posting! Tested Omnirom IRON before this one to and it sucked on Cube u30gt2.
nelySLB
Forum Posts: 34
56
2015/03/01 - 11:51
Oma, Darthjaba can any of you guys help us out and do your magic on this rom, we need bigger app partition or unified memory and all the other goodies you guys costumed us, thanks in advance. i love the overclocked rom.
yes this is almost a tablet now only missing darth and oma customizations to be perfect.
Cuz
Forum Posts: 11
57
2015/03/05 - 13:09
hello all,
Have a nice day !
Rom works great:-).
Rooted no problems with the instructions provided above.
lenniss
58
2015/03/09 - 17:59
Rooted the tablet with the chinese program and fixed the mobile phone battery drain by moving these packages by hand with es filebrowser.
These are the apps that are moved:
/system/app/Email.apk    x
/system/app/Exchange2.apkx
/system/app/GoogleTTS.apk
/system/app/Launcher3.apkx
/system/app/MediaUploader.apkx
/system/app/PrintSpooler.apkx
/system/app/RKUpdateService.apkx
/system/app/Stk.apkx
/system/app/TelephonyProvider.apkx
/system/app/VoiceSearchStub.apk
/system/app/WAPPushManager.apk
/system/priv-app/talkback.apk
/system/priv-app/Mms.apkx
/system/priv-app/MusicFX.apkx
/system/priv-app/TeleService.apk
This is from DJ phone remove zip readme.
My tablet lasts 3-4 days in standby with wifi off. Overclocked version.
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
59
2015/03/11 - 01:58
Has anyone tried this rom from freaktab.com?
http://www.freaktab.com/showthread.php?21374-U30GT2-Custom-KitKat-ROM&p=284356#post284356
Dated 12/31/14
Mark06
Forum Posts: 222
Thanks Received: 41
60
2015/03/11 - 07:40
This can really help i think, include the cpu sleeper app (0.78 euro costs). The cube shows 97 percent and has been on a full day, not used a lot but still. Maybe it goes after the ipad concerning usage on one batteryload.
Cube u30gt2 tab
60 Guest(s)
Devices in use: Desktop (51), Phone (9)
rk.13
siwinfi64
dangphat
dpc
ngu
