Cube U30GT2 Android 4.4.2 KitKat new rom???
I found a ROM from 14.10.2014
Mark06
Forum Posts: 222
Thanks Received: 41
31
2014/11/17 - 18:25
in rockchipbatchtool you can also just connect the tab and push the 'switch'button to connect(green light).
maikal
Cube u30gt2 tab
yewsuck
Forum Posts: 12
32
2014/11/20 - 07:58
Just to follow up.
    This is the best rom I have used so far.  All my graphical tearing and glitches are gone.  It runs smooth and fast like it should have from the start.  I am finally happy with a rom after buying this tablet when it first came out.  ( I done a lot of Roms.)
    If Cube would have had this refined of an OS from the start they would still br selling these tablets at high rates today. Every vendor would be trying to sell this tablet.  Too bad Cube released a bad OS at first launch and killed the sales market they had.  There has never been a good excuse for this tablet to not preform great.  It has great specs, But bad reviews and lots of returns is no way to make a profit!  It killed their sales!   Because of this new Rom I am now able to no longer call this a cheap chinese piece of poop.   Welcome to being an ok tablet maker Cube.  Congrats
-YS
The following users say thank you to yewsuck for this useful post:
lardd
Mark06
Forum Posts: 222
Thanks Received: 41
33
2014/11/20 - 09:59
cube has it's new cube talk 9x with octacore and antutu 43000 score. So in case you still got some money.
Further there is a overclocked 4.4.2 rom which doesn't have the auto rotation bug, you can find it here:
http://www.arctablet.com/blog/forum/cube-u30gt2/cube-u30gt2-android-4-4-2-kitkat-20140219-firmware-darthjabba-mod-in-cwm-upgrade-format/
I mean if you want to play them car racing games, you can't have a tablet where the g orientation is wrong right?
Have just installed it, there is some blurring which can be avoid by turning on the force gpu rendering and the disable hw overlays option in settings. But i don't know if you can set it fixed for after reboot it is still there. But the rotation is all right and it's overclocked. The disable hw overlays option doesn't stay on when you reboot, so you have to select it every time you boot the tab.
ART mode isn't really for now i guess. Every boot it takes a lot of time to convert the apps before you can logon.
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
34
2014/11/20 - 13:32
Mr.Nice said
Hallo,
I have found this ROM, but I can not find out if this is a new from 51Cube.
Forum link: http://bbs.51cube.com/forum.php?mod=viewthread&tid=97337&highlight=u30gt2
Download link: http://pan.baidu.com/s/1mgNwnhu
I'm not so good at Chinese :)
My question,
Is there anyone who can see if this ROM will work and be stable.
I look forward to some feedback.
You can also take the one from 06 06 2014 kastyrom 4.4.2 and throw the widgets away. Am curious whether overclocked or not the battery usage makes a lot of difference. Rule i think is keeping the tab as cool as possible, so no heat.
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
35
2014/11/20 - 17:33
Just compared the two firmwares, the chinese and the kasty from june. The chinese non overclocked, seems more vivid.It is faster in multitasking, but there is one thing. I had when copying and surfing the web one reboot out of nowhere. Further the rom is very good.
Cube u30gt2 tab
saciorlux
Forum Posts: 22
Thanks Received: 5
36
2014/11/20 - 18:43
What language is the rom? is rooted?
http://saciormeteo.no-ip.biz
Mark06
Forum Posts: 222
Thanks Received: 41
37
2014/11/20 - 18:58
You can alter the language (go to settings and the alphabetic sign and the upper option), i did an wmshua root after installation to root it. Origin the rom is chinese, but you can alter this.
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
38
2014/11/20 - 19:33
with an otg micro usb to usb converter and a wifi mouse and keyboard you can make your own tablet pc( connected through hdmi to television). Works very good with the new  rom. Have deinstalled the powersaver that is installed.
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
39
2014/11/22 - 08:52
Install nova launcher and activate fast as lightning.
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
40
2014/11/22 - 10:47
the chinese rom non overclocked worked really fast, also when connected to a tv. But the day after it was very much slower. Is this to solve by going into recovery mode and wiping the cache?
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
41
2014/11/25 - 04:59
With the R software preinstalled you can easily root it(logo r).
There is a fix for the screen rotation bug. Install build prop editor and change the value of 'ro.sf.hwrotation' from 270 to 360 degrees. I now am happy with the good working chinese overclocked version from 10 29 14. Had to install arctools to install the deep sleep fix. This helped avoiding unnessesary reboots.
Cube u30gt2 tab
kikimora
42
2014/11/26 - 12:02
I'm on KitKat (DJ's 4.4.2), i.e. gen2 loader. Is it ok just to donwload the Chinese stable version from page 2 and install it using Rockbatchtool? No loader change or anything else needed?
(Btw the DJ's 4.4.2 is ok for me except the battery drain issue. I hope this new Chinese ROM improves battery life. I installed new batteries 2 weeks ago but the battery life has has not improved.)
yewsuck
Forum Posts: 12
43
2014/11/26 - 13:21
you will be fine.  But you will lose all the tweaks that DJ added.
kikimora
44
2014/11/26 - 14:30
Thank you. Concerning battery drain issue, can someone comment?
I suppose, Oma7144's Lollipop ROM (http://crewrktablets.arctablet.com/?p=4316) is not quite suitable for an inexperienced user, right?
Mark06
Forum Posts: 222
Thanks Received: 41
45
2014/11/26 - 14:46
It works a bit slow, the lollipop version. Batterylife is reasonable, not extended much.
Cube u30gt2 tab
74 Guest(s)
Devices in use: Desktop (65), Phone (9)
rk.13
siwinfi64
dangphat
dpc
ngu
