Cube U30GT2 Android 4.4.2 KitKat new rom???
I found a ROM from 14.10.2014
Mr.Nice
2014/11/15 - 10:50
I don't know a lot about the Android building blocks, but if it's a driver problem why don't they use the one from the stable version.
I found a bug in the stable version, it losing the homescreen shortcut just like the version 19.02.2014.
I found in a forum that this is a bug in Android 4.4.2, and will be fixed with 4.4.3.
But I still love it, I on plug the charger last night 22.00 and used it half a hour. And now 12 hours and 35 min later it still has 97% left on the battery.
Mr.Nice
2014/11/15 - 12:08
I "solved" the icon problem. Wink
I install a program call Folder Editor, it makes a widget on the home screen.
And then you just put all you shortcuts in there, after restart the widget is still on homescreen. Laugh
When click on the widget a window open with your shortcuts and you can choose opening styles.Cool
The following users say thank you to Mr.Nice for this useful post:
maikal
Mark06
Forum Posts: 222
Thanks Received: 41
2014/11/15 - 12:28
Rotate is the best screen rotation app. It works seamless with android user interface. Ok good thing mr nice!
maikal
Cube u30gt2 tab
yewsuck
Forum Posts: 12
2014/11/16 - 05:16
Could you please post a new link to the Rom?   I am having a problem getting the linked Rom.  Me not understanding the language is probably the problem.
   So do you think it is better to use 14.10.2014 Rom or the 201406006 Rom?
Thank you and Regards,
-YS
Mark06
Forum Posts: 222
Thanks Received: 41
2014/11/16 - 10:19
you should download the chinese rom by your tab. Then it shows you an app to download which again download the file. This is the fastest way to get the rom. Then you have to flash your tab through rockbatchtool.
maikal
Cube u30gt2 tab
yewsuck
Forum Posts: 12
2014/11/16 - 11:20
I tried again using a translator.  No luck.   I tried both the Download manager (10mb file)  and the direct download.   The download manager requires that a person have a Chinese cell phone number to finish registration.  I do not live in China.   The direct download says to try again later.   I been trying all day.  A different download location will be needed for the rest of us to get the file I guess.   Oh well.   I will try again another day.
Mark06
Forum Posts: 222
Thanks Received: 41
2014/11/16 - 11:25
The downloadmanager on your cube does't need registration.
maikal
Cube u30gt2 tab
yewsuck
Forum Posts: 12
2014/11/16 - 14:00
Oh thanks.  You are right the Tablet App does not require registration.   I am downloading the Rom now.   Thank you.
-YS
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
2014/11/17 - 00:43
This is great news mark6. Can you give us a step by step of what you did, including added apps so we can have it all on one post? It would be easier to follow. Mr. Nice would you follow up with anything else you might have added or done? Great work. My tablet is still in repair shop, but I cant wait to get it back to try this new rom!
Please include which kernel you are using in overclock too! How is heat on tablet with either kernel would be nice to know as well as which launcher works for you.
Thanks again for the work. Anything that makes the Cube keep on ticking is worth trying!
maikal
Forum Posts: 394
Thanks Received: 51
2014/11/17 - 00:54
Firmware based on the Funrom is here: http://www.arctablet.com/blog/forum/cube-u30gt2/rom-cube-u30gt2-android-4-4-2-kitkat-custom-root-firmware-20140606/
Oma are you saying that the rom Mark6 found is the same as the one on link you posted?
maikal
Forum Posts: 394
Thanks Received: 51
2014/11/17 - 00:56
yewsuck, how is rom working out? Did you try it?
yewsuck
Forum Posts: 12
2014/11/17 - 08:06
   I have tried it and it seems better than the 4.2.2 Rom that I was using before.  I do not have the same graphical glitches as before.  So that is good.  All my programs seem to work.  A few of them force close every so often.  That might be due to my programs being installed using a back up installer.   I am still testing programs.  I will be keeping this Rom for now.
   I spent most of the day trying to figure out how to root the tab with no luck.  That is a bummer for me as I like using programs that need root.   I tried two Root programs One said it was already rooted, so I tried to unroot then it said it was already unrooted. hahah  The other appeared to work but did not actually give root.   My root required programs will not work with the stock install or my attempts to root.
   To get the IMG file I had to use my tablet to go to the download link provided.  I clicked the Orange button.  It installed a App.  Opening the App started a downloader.  Once the Rom was downloaded I transferred it to my PC and did the Rockchip batchtool 1.7 Restore.  That is it.
ROM Details below.
FW Ver: 4.4.02     FW Time: 2014-10-29 12:52:26
Boot Ver: 2.09      Boot Time: 2013-12-16 14:52:00
Model:U30GT 2
Firmware version:4.4.2
Android Version:4.4.2
Kernel version:CUBE-eng 4.4.2 KOT49H eng.root.20140211.100632 test-keys
Kernel Version: 3.0.36+  tangy@tchipserver2#95  Sun May 4 15:50:58 CST 2014
Build Number: U30GT2_4.4.2_V2_141028
OMA,  If this is a different version than the 06 FunRom could you please do your magic on the rom?  I would be a very happy person.   Thank you for all your support of this tablet.  :)
The following users say thank you to yewsuck for this useful post:
maikal
Mr.Nice
2014/11/17 - 08:57
Help with the download :-)
Stable version
Download link: http://pan.baidu.com/s/1mgNwnhu
Overclock version
Download link: http://pan.baidu.com/s/1pJmcywz
Forum: http://bbs.51cube.com/forum.php?mod=viewthread&tid=97337&highlight=u30gt2
Click on download button, the one with MB on it. (I just used my computer)
Then click on the button that is gray and it will download. If you click on the blue button a program pops up for download.(And you don't need it)
maikal
Mark06
Forum Posts: 222
Thanks Received: 41
2014/11/17 - 10:25
ROM Details below.
Model:U30GT 2
Rockbatch tool: power up rockchip batch tool, power off cube, hold volume plus while connecting to pc, keep pressing volume til rockbatchtool gives green light. Now you're tab is connected and you're ready for flashing the image file. Alternative flashtool:
http://www.marsboard.com/marsboard_rk3066_download.html
Rooting: install adb drivers: http://www.adbdriver.com
install root tool: http://download.wmshua.com/WMShuaSetup.exe
connect the tab, let the wmshua program fine out you've got a cube, then go to tab root/unroot and select down the second root option on the right. This might take some time. If is good the percentage drops from about 97 back to 90 for three times(three tryings to get it done), then it shows rooted and reboots the device. This is how i got my (overclocked) chinese 29102014 rom rooted.
maikal
Cube u30gt2 tab
yewsuck
Forum Posts: 12
2014/11/17 - 15:51
Your a life saver!  thank you!    I installed wmshua and used your instructions above on a fresh install of the Rom. It rooted just fine.
I have used this Rom all day and it is great!   Much better than the previous Rom I was using.  Thanks all.
maikal
73 Guest(s)
Devices in use: Desktop (65), Phone (8)
rk.13
siwinfi64
dangphat
dpc
ngu
