Cube U30GT2 Android 4.4.2 KitKat custom root firmware - test overclocked kernels
bk79
61
2014/03/08 - 23:23
I've tested 798 gpu, antutu goes scored 21360 with no wifi on, right now I'm testing t15 1800 768 720, but at 1800Mhz  I had a couple of reboots when running antutu, I tried maxing the frequency to 1608 and I had no reboots during the various antutu's tests (scored 20126.. I think the lower voltages won't cope well with 1.8 Ghz frequency, or probably heat sinking is not enough on my tablet and during heavy load thermal increase will decrease stability
One question...is it possible to have a t15 at slightly lower frequency that 1.8 Ghz? and a gpu at 798?
Update: I had a reboot also after maxing at 1.6 at the 4th antutu test...switching back to t14  1800  798 750
Update2: Today I opened my tabled to try solving the poor wifi signal and found that most of the cable are poorly set inside the sockets, wifi antenna was shortcircuted (I wonder why...). I fixed everything ( new battery is still on the way), and I enlarged the heat sink on the cpu/gpu/ram using alluminium foils in more layers so to extend the surface to the whold tabled....Now even running with t14 1800 798 750 at full load my tab is barely warm. I wonder if it's worth trying  pushing more the hardware with this solution...
The following users say thank you to bk79 for this useful post:
maikal
DarthJabba
Forum Posts: 551
Thanks Received: 396
62
2014/03/09 - 22:11
Interesting stuff! But for now, I am done with producing overclocked kernels ...
bk79
63
2014/03/09 - 22:13
what a pity I'm creating some based on your T14 kernel lowering voltage a little, one strange thing I've noticed is that ddr at 800 gives in antutu less than the same kernel with 720
bk79
64
2014/03/09 - 22:27
Just a question, on t15 I',m unable to find the offset for the ddr do you have any hint on that?
DarthJabba
Forum Posts: 551
65
2014/03/10 - 23:56
It depends - but you could start with offset 0x9ba29c. If you're looking for a principle, search for occurrences of this sequence: 00 00 00 00 fe ff ff ff and the values coming after them. Some will relate to cpu, gpu, etc., and eventually you will find the ddr stuff. In each case, you will find the voltage first, then the frequency (separated by nulls), etc., in a chain, until that chain is finished (usually by the sequence above). The bytes are reversed. You need to know what you're doing - and doing it manually is extremely error-prone. I would not recommend it. If you get one bit wrong, you might end up with a boot loop - or worse.
aurel.14
66
2014/03/19 - 20:43
Hy and thanks for this partage and files
I partage my results :
kernel_305kitkat_cpu1800_t14_gpustock_ddrstock                      19966
kernel_305kitkat_cpu1800_t14_gpu798h_ddrstock                       20916
kernel_305kitkat_cpu1800_t14_gpu798h_ddr600                          21670 UNSTABLE - REBOOT
kernel_305kitkat_cpu1800_t14_gpu768h_ddrstock                       20392
kernel_305kitkat_cpu1800_t14_gpu768h_ddr600                          21335
kernel_305kitkat_cpu1800_t14_gpu768h_ddr667                          21468 UNSTABLE - REBOOT
kernel305kitkat_cpu1800_t15_gpu768_t15_ddr720                       22132
Where we can find all t15 filles ? i would like test with 7998 gpu
DarthJabba
Forum Posts: 551
67
2014/03/19 - 21:22
There are no other T15 files. T15 was abandoned ...
nelySLB
Forum Posts: 34
68
2014/10/06 - 09:17
I your t14 kernel makes mi tablet orientation wrong
Mark06
Forum Posts: 222
Thanks Received: 41
69
2014/10/13 - 14:27
I'd like to see a cpu app that really shows the 1.8 ghz from the cpu while overclocked. Is there a possibility for this?
grtz mark1978
Nelyslb i had that too with my cube tab
Cube u30gt2 tab
DarthJabba
Forum Posts: 551
Mark06
Forum Posts: 222
Thanks Received: 41
71
2014/10/17 - 10:16
It works 1.8 ghz. Antutu score is 25000. Screen doesn't rotate right though,  so had to turn it off.  Can you fix this?
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
72
2014/10/17 - 10:36
I installed screen rotation control and set landscape mode.
Cube u30gt2 tab
DarthJabba
Forum Posts: 551
73
2014/10/17 - 14:04
My Cube died a few months back, when I dropped it, so I can't do any more Cube tweaks.
I hope the control you installed solves your problem.
Mark06
Forum Posts: 222
Thanks Received: 41
74
2014/10/17 - 15:42
Yep it's working great, just a bunch of funny colours within my browser now and then. Keyboard is working all right now, games do fine too.
Cube u30gt2 tab
Mark06
Forum Posts: 222
Thanks Received: 41
75
2014/10/18 - 09:07
I used overclock kernel 305 kitkat cpu 1800 t14 gpu798 ddr72
Rom kastycube 20140606
Cm browser
Cube u30gt2 tab
182 Guest(s)
Devices in use: Desktop (180), Phone (2)
PUNTOUS
ahujcibugs
edneijovenase
thanhgom2006
hoholms
rammaiden
