2013/12/16
DarthJabba said
A new record for the Cube! Using the overclocked #352 kernel (cpu1800, gpu768, ddr720) I've got an Antutu score of 22357.
I'm joining to Club22k+ with my 22097 That's on #352 kernel (cpu1800, gpu768, ddr667). Other benchmark scores are down below with percentage difference compared to beta1 (cpu1800, gpu798, ddr667). The UI experience is much better now, but benchmarks show that gaming should be much better too. Overall, I'm quite happy with the changes Cube did in this beta.
The only bug I have noticed so far is some weird screen flickering (like a vsynch over 60fps), and screen corruption (but only on a small part of the screen for a brief time). Some people also reported it before me. Most of the time it happens on the navigation bar on the bottom, when scrolling launcher homescreens, when scrolling apps in Settings/Apps, when browsing the content inside gallery, and even in 3DMark and NenaMark2 benchmarks, so I guess it will be visible in other apps sooner or later. I still can't confirm that since I'm completely stock now, but anyway it would be nice to get rid of it. So if anyone knows how to deal with it, I'm open to all suggestions.
And now the results...
Benchmarks (FHD):
AnTuTu = 22097 (+3,6%)
Quadrant = 6043 (+7,3%)
T-Rex HD = 7fps (+16,7%)
Egypt HD = 18fps (+20%)
NenaMark2 = 60fps (+36,4%)
Epic Citadel = 50fps (+51,5%)
3DMark = 4197/3151/4207 (+18,9%/+13,4%/-0,2%?)
maikal
2013/12/16
And one more thing worth noting. If you're using the stock launcher (I think it would be no problem with others), do not ever disable or freeze Google Search in this beta! I like to do that because I never use it, and it doesn't reminds me every now and then about the update. If you do disable it, then the first side effect will be not able to get back to homescreen. And if you undo your changes while you still can, then that's no problem at all, but if you restart your Cube (like I did, thinking it's something else), they you will find you can't boot your tablet as it will be waiting on the animated Cube logo indefinitely. But that's not where the fun starts, because even restoring your CWM backup won't help. Not even completely wiping the whole damn thing, and installing fresh CWM rom (for the life of me I can't figure out why that didn't help). The only way to bring it back to life (at least in my case) was flashing Kasty's rom with RKbatch tool first, and then do the whole thing over again (CWM, JB rom, mods, kernel, setting up the settings, restoring apps, ...). Arrgghh. Now I did the same mistake, but I was carefuly checking if everything's ok after each major step, so I was able to figure out what is going on. If I was a developer of that stupid stock launcher, I wouldn't go into infinite loop waiting for Google Search widget to automagicaly appear from somewhere, I would instead not load it or something. And that's how it was on every rom until now. But the way it is now, all hell breaks loose because of that widget. So save yourself a headache, and leave that alone.
maikal
2013/12/16
DarthJabba said
Congratulations!
I haven't built any gpu798 overclocked kernels this time - perhaps I should?
If you decide to do it, I can test it on my Cube too.
And I tried #352 ddr720 too, but it wouldn't boot up again.
Before on #305 it could hardly get into recovery or was giving a black bricked screen, so I guess now is a little bit better lol But it seems to me it's not worth ~250 AnTuTu points (difference between our scores).
EDIT: the "flickering effect" sometimes also happens when slowly swiping apps from the recents menu. I would say it's something to do with the video drivers. And possibly with the added performance in this beta. Like vsynch is set to off in specific cases where performance is needed, so screen tearing effect shows up. Just wild guessing. Does anyone else experience it?
maikal
2013/12/16
Did someone noticed there is no cursor (|) inside any of the text boxes? It's somewhat harder to navigate text inside it. Anyone with that bug? Or is it a feature?
Also forgot to say that battery drain and stand-by time are better than in previous betas. At least on stock settings/apps. Now after restoring my apps, I will see if that remains the same levels...
I changed my launcher to Next Laucher, and it seems the fickering is somewhat better now. Can't say it's gone completely. Will test it more thorughly later, because now I'm left with 2% battery...
Last but not least, my camera LED started working again. Weeeee! I just don't know what to do with it lol
maikal
2013/04/23
@Burs: yes, I've noticed that there is no cursor in the text boxes - but this is something that I can live with.
I have updated the first post with gpu798 overclocked kernels (download #5). There is "gpu798h" (which is based on the original T14 specs), and there is a new "gpu798ht" ("t" stands for "turbo"). The main difference lies in the in-between frequencies (higher in the turbo version).
To be honest, I haven't found a great improvement in gpu798 over gpu768; and 798 runs hotter. I have gone back to gpu768h, but your mileage may vary ...
Burs, maikalDarth Jabba, the Dark Jedi from Nal Hutta
2013/07/09
2013/04/23
maikal said
So those gpu 798h kernels are the same as the ones we tested before, that are in the repository you put together for us ...
No, they are not. These are based on the new kernel #352. The ones that were released before were based on the old kernel #305.
2013/12/16
traysub said
I only have "flickering effect" Â on the modified kernels, on stock kernel there is no screen flickering effect.Â
Haven't thought about that... Why doubting DarthJabba's work?
But I will try stock one too, and see how it behaves on my tablet.
It seems it's flickering "only" when someting's scrolling on the screen...
74 Guest(s)
Devices in use: Desktop (65), Phone (8), Tablet (1)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
