2013/12/16
DarthJabba said
jesmail said
now off to try over clock....A new record for the Cube! Using the overclocked #352 kernel (cpu1800, gpu768, ddr720) I've got an Antutu score of 22357.
Very nice! Congrats on having the fastest U30GT2 Tell me, with all those DDR720 kernels failing on my Cube before, is there any sense rechecking them on this beta, or it's simply due to hardware's voltage and frequency tolerance? I guess it's the latter, but it doesn't cost me anything to ask
I'll benchmark mine before I do a restore of all apps, but after I decide which kernel I will be using.
2013/05/06
Well, almost everything seems to run smoother. Â But Antutu crashes at 21% Â and forces the cube to reboot. I got other forced reboots when using the TouchPal keyboard. Â I already had this problem with ALL the OC DJ's kernels, maybe because my cube is an early production (March 2013). Is there a chance to get the original #352 kernel? Otherwise I'll be forced to go back to beta1...
Thanks for your great work!Â
2013/04/23
There's no harm testing them, but I would be surprised if they didn't fail too. I think the DDR667 kernel should perform nearly as well as DDR720, while possibly being more stable on indifferent hardware. I guess I'm one of the lucky few that got rock solid hardware. I only get problems when the DDR is overclocked to 800 or more.
BursDarth Jabba, the Dark Jedi from Nal Hutta
2013/07/09
DarthJabba said
maikal said
Darth can I use the kernel I have now? The t14 798/720_04.I would have thought so - but then you wouldn't get the advantages of the updated kernel. I have added a zip file containing 3 overclocked kernels in CWM format to the first post (above).
So per your comment regarding the advantage of the Kasty rom updated kernel, are you saying that opting for the other kernels you posted would not bring the advantages of the original Kasty rom's kernel?
And thank you for the work DarthJabba, once again you have come through for all of us.
2013/04/23
The previous Kasty KitKat had kernel #305. All my original overclock tests were with that kernel. I have since streamlined the overclocked kernels and narrowed the best of them down to a few, which I have now applied to the kernel #352 in the most recent Kasty KitKat. Presumably the new kernel has improvements in it, in which case you would want to use it. This doesn't mean that the #305 based kernels are not useful - but you might be missing something if you stay with them.
maikalDarth Jabba, the Dark Jedi from Nal Hutta
2013/07/09
Thank you again, you have given me something to think about. Hmmm.
67 Guest(s)
Devices in use: Desktop (58), Phone (8), Tablet (1)
wemiy54158
sidor
houssmen
qarolus
dav512
tgergely2012
