New firmware update 2.04 just published:
2013/06/29
So I installed the 2.03 version on my CUBE U30GT2 today and so far everything is working excellent! The only issue I have had is with netflix, the app works but when streaming the picture doesn't display properly. Other than that I have to say, this is probably the best running firmware on my U30GT2 so far. It seems so fluid and has great touch response! Thank you so much!
I had a few questions:
- Is there a specific place I should report bugs, if any, or may I post them here?
- Was it confirmed that this release does not support multiple users?
- Does anyone know what might be going on with my netflix streaming? Ever since the first time I upgraded to the 4.2.2 beta I have had issues. I thought it would go away once I installed a new firmware but it hasn't. Another user told me that they had no issues with the app or streaming on this release. But for some strange reason when I stream videos on netflix the picture is split into two and you can see all the interlaced lines. I was hoping someone may be able to put me in the right direction of solving this issue. I can post screenshots if needed.
You can report problems in this particular topic if it's related to firmware 2.03 or create a specific topic to bring attention on a particular issue.
I can't say reported bugs will all be treated, but we'll try to have a look. It's not easy for the U30GT2 as we actually don't own a tablet.
You should check our U30GT2 forum section regularly as there are updates on Cube's firmware and our custom firmware. I'm pretty sure the streaming problems will be gone in a couple of updates.
As for multi-user support, this can be added with a build.prop file modification. We should soon publish an ArcTools package to make the change easier.
2013/06/29
You can report problems in this particular topic if it's related to firmware 2.03 or create a specific topic to bring attention on a particular issue.I can't say reported bugs will all be treated, but we'll try to have a look. It's not easy for the U30GT2 as we actually don't own a tablet.
Awesome! No worries, I understand. To be honest, I am just grateful that you take the time to modify the firmware for the U30GT2 so the rest of us can have a fine tuned device. As a future software engineer (I'm pursuing a Bachelor's degree in computer science majoring in computer programming) I really respect that.
I'll definitely watch the forum for future firmware updates. After my experience with your custom version 2.03, I am very happy. My U30GT2's performance has increased significantly compared to Cube's official.
I did find a forum post on here with instructions about editing the build.prop file to enable multi-user, but I wasn't sure if it would work on this release. I used ES file explorer to edit the file like the post suggested, but when I added fw.max_users=5 to the end of the file a bunch of lines in the file became underlined in red so I was unsure if I was doing it correctly. I don't know anything about the build.prop file, but I was told that if it is altered incorrectly it is possible to brick your device (not sure if that is true) so I figured I should talk to someone who is more knowledgeable on the subject. Anyway, is that normal for the contents of the file to become underlined in red once it is edited or did I do something wrong?
2013/06/15
someone is having problems with installing Chainfire3D this rom or I'm having bad luck? after installing the driver Chainfire3D, the device is in loop only doing a fresh install of rom for it return to normal.
this blog the author says that the superuser doing this.
blog link:
http://www.androidnz.net/2011/10/at-your-own-risk-how-to-use-chainfire.html
Not superuser is doing that, Chainfire3d IS NOT COMPATIBLE with any rockchip device, this happened on Arnova 9G2, Archos Gamepad
eeprom
2013/04/27
So I installed the 2.03 version on my CUBE U30GT2 today and so far everything is working excellent! The only issue I have had is with netflix, the app works but when streaming the picture doesn't display properly. Other than that I have to say, this is probably the best running firmware on my U30GT2 so far. It seems so fluid and has great touch response! Thank you so much! I had a few questions:
-Just install older version of netflix apk, and dont forget to switch off updates for the apk
2013/06/29
Thanks, but I tried that and it is still behaving the same. It's very strange. I'm not sure what to do about it.
2013/06/13
Why dont u use the last firmware btw ?
2013/07/26
I'd rather keep with 2.03 for now since people are reporting issues with the 2.04 beta. But I guess I might have to wait for the 2.04 final if I can't download this one.
2013/04/23
Try the attached package (in CWM update format) - the files are from the last ROM release that apparently does not drain the battery. If it works, then please let us know.
Installation:
1. Copy this zip file to the tablet's SD card
2. Reboot the tablet to CWM Recovery
3. Select "Install zip from sdcard"
4. Then select "Choose zip from sdcard"
5. Scroll on the SD card to this zip file, and select it
6. Confirm that you do want to install it; the installation process will take several minutes.
7. The tablet will reboot back to the CWM Recovery
8. Select "Reboot system now"
9. Go and make a cup of tea and sandwich.
10. Drink the cup of tea and eat the sandwich; make sure you spend at least 10 minutes doing this.
11. Come back to the tablet after 10 minutes. Everything should be ready now.
DISCLAIMER:
You use this mod entirely at your own risk! If your tablet is bricked, then that is too sad. If you are worried about bricking your tablet, then STOP RIGHT NOW !!!
maikalDarth Jabba, the Dark Jedi from Nal Hutta
76 Guest(s)
Devices in use: Desktop (71), Phone (5)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
