2013/05/27
Matrix44 said
Hi,me and my friend bought this great tablet. We have tried several ROMs, but we keep having one problem. When we plug in the charger and start charging, it becomes less accurate, the reactions of the display become worse and unpredictable. As if the touch screen was not ok. When the tablet is charged and unplugged, everything is ok again. All tablets do this from the beginning, with all tested ROM.
Does this happen to you too? Is it OK?
Many thx,
Matrix44
Well to give you an answer from the experience i have with chineese tablets that they all do this wierd thing with their screens when the power adaptor is connected.
I have 3 different brands of chineese tablets here at home and they all do this.
The following users say thank you to warsound for this useful post:
Matrix44
2013/04/26
Many thx,
Matrix44
are you using windows 8??
that problem happens to me on windows 8 and doesn´t on another pc with windows 7. not sure why, heh
2013/04/18
Hi, tried this latest release, and now the tablet doesn't connect to my router , just keeps initiating , changed settings in router and tried all channels, still same, this is getting frustrating, think best firmware is 4.1.1 1.05 and its battery life is better on that,
also not perfect smooth playing mkv files, im thinking of selling this now, and just getting a branded tablet like the sony tablet z , keeps getting new updates but i aint noticing anything getting fixed , well not face value
2013/06/15
Many thx,
Matrix44
Brnky said I have the same ones problem during charging. Install the ROM with another OS than Win 8? Can you confirm? It could suggest a poor loader Rom? thanks
DarthJabba said I would imagine that it is a problem with the power adapter.
@ Sethi and Brnky - I don't see what charging of the tablet and the OS in my PC would have in common?
@ DarthJabba - it's probably not a problem of the adapters, we tried 3 different adapters so it is not very likely that all of them would be faulty. But @warsound wrote that all of his Chinese tablets do this. Your does not?
I have a chinese duo-core PiPO as well and this tablets does not have this problem.
Have a nice day,
Matrix44
2013/04/23
Matrix44
No, it does not. It is perfect in every way. But I have a Chinese smartphone (Star S7589), and it was doing just that kind of stuff when it arrived. I discarded their power adapter, and used one I had before, and everything was fine. The seller sent me a replacement adapter (from China), and it was dead on arrival. He wanted to send yet another one, and I told him to forget it - I already had a few (from old HTC and Samsung smartphones) which worked fine. Apart from that, the phone itself is great.
Conclusion: Chinese devices have some quality assurance issues - you might get one that is perfect, and you might get one that is dodgy. It seems to be a lottery.
Bottom line: if you don't want to take any risks, or, if you are not a techie, then you might be well advised to buy a Samsung, or Sony, or Lenovo, etc., and pay the extra price for the extra peace of mind. Personally, I am very much a techie, and I am happy take the risk. I always buy Chinese now ...
2013/04/18
DarthJabba said
Matrix44 said
@ DarthJabba - it's probably not a problem of the adapters, we tried 3 different adapters so it is not very likely that all of them would be faulty. But @warsound wrote that all of his Chinese tablets do this. Your does not?Matrix44
Hi, what do you mean by being very techie ? , this latest update stopped it working with my router, no matter what i do with router settings, wireless channels , but older rom works,
also could you get perfect smooth play playing MKV files like i get on sony tablet z ? and now flash within browser doesnt work at all just sound, need to play in normal screen and zoom , older rom flash worked on full screen but it was not smooth, all these releases they doing doesnt seem to make this any better, probably worse
2013/04/23
uscool said
Being very techie is being easily able to do techie stuff like flashing firmwares, etc. I don't have any problem with wireless; I am using the kasty firmwares.
Yes, I get smooth play with mkv files, using the Archos video player that is in the apps.zip file that someone on this forum has provided.
2013/04/18
DarthJabba said
uscool said
Hi, flashing roms is straight forward i tried alot since i got tablet, guess wireless depends what router you have as there are many out there, its frustrating as all the older roms the wireless worked fine on same router, will have to try archos player to see if mkv are any smoother, Thanks
81 Guest(s)
Devices in use: Desktop (75), Phone (6)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
