[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.03 (2013/06/06)
DarthJabba
Forum Posts: 551
Thanks Received: 396
2013/06/13 - 23:15
3/ I don't think this firmware is multi-user enabled, but I'll probably soon provide another ArcTools package to do that as well.
Don't you just need to make an entry in the build.prop before building the firmware image? I would have thought it would be better to have this already in the firmware, rather than to do a fix subsequently. Ditto for the Phone.apk debacle - the problem is not going to disappear until they fix something in the kernel, and one of the advantages of a custom firmware is that you can fix (before release) things that are broken in the official firmwares.
BTW: many thanks for these custom firmwares.
Thanks Received: 3177
2013/06/13 - 23:24
I agree with you, but I can hardly believe that these bugs/features are left uncorrected by the manufacturer  over each releases. I'm convinced there is a reason they left Phone.apk, maybe for 3G related functions ? Multiuser is maybe not enabled because it's not stable ? I'm relying the community feedback to decide if these changes should be integrated in the custom firmware, but until there is enough feedback, I'd prefer to leave that stock and help the users to make the changes easily thru ArcTools. I hope that makes sense...
Bsoft2007, fana75
uscool
Forum Posts: 11
2013/06/13 - 23:38
Hi, flashed this, still flash dont display in full screen, also now my wifi doesnt connect , im really thinking of selling this tablet now :( , but thanks for the updates
rupeshcartel
2013/06/14 - 00:02
uscool said
Hi, flashed this, still flash dont display in full screen, also now my wifi doesnt connect , im reay thinking of selling this tablet now :( , but thanks for the updates
If you use the built in player for flashmovies and just zoom the window to fullscreen, or you can use boat browser.
DarthJabba
Forum Posts: 551
2013/06/14 - 00:12
Yes, it makes sense - but you would be surprised at what manufacturers can sometimes leave unfixed, sometimes because they don't know how to fix it properly, and sometimes because they don't consider it a priority. I have seen, in developing custom firmwares for embedded devices in a former incarnation, shocking things left behind by manufacturers that are much bigger than any of those we would talk about in this forum (and I am talking about HUGE multinationals). After all, it is just human beings who do the actual coding ...
Raska501
Bsoft2007
Portugal
Forum Posts: 36
Thanks Received: 8
2013/06/14 - 02:32
Does anyone have tried to set APN and save the config?
I've tried to set it several times and I can not save the settings.
Can not use my Huawei E220.
Has anyone tried to do this?
Uznamer
Poland
Forum Posts: 42
Thanks Received: 12
2013/06/14 - 14:34
Sethi said
Any1 can tell if HDMI Screen Time Out Fixed?
no point in upgrade, really, if no major thing "fixed", hehe
Sethi, you are absolutely right! I don't understand what for are all those last upgrades when they are not fixing any bugs we are talking here about within last few weeks. Maybe they are just some minor corrections which we regular users cannot even find.
fana75
Forum Posts: 30
2013/06/14 - 15:55
"2/ Phone.apk is still installed, I leave removal option to the user, for example using this ArcTools package, ArcTools is preinstalled in the firmware, the procedure takes less than 30 seconds to do."
How could i verify that the phone pacth works????
I used toor cleaner to reset the Battery statistic but after a reebot i still have in the new battery statictic a red line corresponding to phone....
How to be sure that it works....
Using arctool many i failed many time in installing the patch error 28 and then 20 (can not create a temporary directotry)....
One time i clicked on install apps while there is nothing in the tab above
=> it installed some apps...
What are the default patch installed?
Regards
Goldi6
2013/06/14 - 20:41
First of all, thank you admin for your hard work.
I think about selling the tablet too.
I only need the video fullscreen and a long battery time to watch video streams.
Every time there is a new firmware I read about battery problem and no video fullscreen.
I went back to 1.03 where these two things work but its running not that smooth as the newer ones.
Its a little bit frustrating.
yoavst
Forum Posts: 51
2013/06/15 - 10:17
this firmware has a lot of lags, for exmple when i try to open an app from the app drawer it took 10 seconds to start
DarthJabba
Forum Posts: 551
2013/06/15 - 15:10
I don't have any lags. Try rebooting.
yoavst
Forum Posts: 51
2013/06/15 - 15:32
It doesn't help.
DarthJabba
Forum Posts: 551
2013/06/15 - 15:33
Yes, it is. But these problems seem to be easily resolved.
DarthJabba
Forum Posts: 551
2013/06/15 - 16:51
yoavst said
It doesn't help.
Hmmm ... I'm not sure what's going on there - did something go awry with the firmware upgrade?
This is probably a long shot - but if you have CWM recovery, you can try rebooting into CWM, and clean the cache and dalvik cache.
Matrix44
2013/06/15 - 18:06
me and my friend bought this great tablet. We have tried several ROMs, but we keep having one problem. When we plug in the charger and start charging, it becomes less accurate, the reactions of the display become worse and unpredictable. As if the touch screen was not ok. When the tablet is charged and unplugged, everything is ok again. All tablets do this from the beginning, with all tested ROM.
Does this happen to you too? Is it OK?
Many thx,
Matrix44
201 Guest(s)
Devices in use: Desktop (190), Phone (11)
ppaofe
kabelodinternetu
waterwall
sufak79
ntukinal
Miguelcnc
