[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.03 (2013/06/06)
2013/06/13 - 15:47
Update 2013/09/13: Custom firmware rebuilt with our latest modifications.
Here is an Android 4.2.2 Jelly Bean rooted firmware for the Cube U30GT2 tablet based on latest Cube official update version 2.03 released 2013/06/06.
(U30GT四核豌豆2_V2.03_20130606.rar)
Kernel: Linux version 3.0.36+ (lcp@tchip-super) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #35 SMP PREEMPT Thu Jun 6 16:08:57 CST 2013
Android 4.2.2 Jelly Bean: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.lcp.20130605.172239:eng/opinions-on-teclast-p90hdst-keys
According to the manufacturer this update version 2.03 fixes the following:
1 optimization problems can not connect Cisco routers;
2. optimize fuel gauge shows the percentage of the problem of inaccurate
Custom firmware features (updated 2013/09/13) :
  • root with latest SuperSU version 1.60 (free version)
Download: kasty-cube_u30gt2-422-203_20130606-rooted4b.zip
Please flash with Rockchip Batch Tool 1.7, use Restore button.
riangey, nefsim, robiom, sipdude, Baeckman, Iemand, rupeshcartel, Bsoft2007, ElVinche, vildkatt, Sync_One, cuberiordan, booli123, kabarazab, Ohamn, saykooo
nefsim
2013/06/13 - 16:26
thank you...
cocoinasia
2013/06/13 - 17:28
Thank You
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/13 - 17:36
This is out for 6 days now ... weiiiiiiiird :x
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/13 - 17:38
Any1 can tell if HDMI Screen Time Out Fixed?
no point in upgrade, really, if no major thing "fixed", hehe
The following users say thank you to Sethi for this useful post:
Uznamer
vildkatt
Forum Posts: 16
2013/06/13 - 20:42
It would be fun to hear what is really new/fixed with this release.  It looks like the kernel is the same as before.
The notes are pretty brief on the changes, but I guess they are just making minor changes now.
fana75
Forum Posts: 30
2013/06/13 - 21:13
Dear all
Thank you, but the link is dead
Could you tell if in this new release:
1/ there is 4Go for APP?
2/ phone.apk is moved away in order not to have a huge power consumption
3/ how many users max are defined for the multiuser
Regards
2013/06/13 - 21:29
Which link is dead ? I have no problem downloading.
About your questions:
1/ I have updated the storage space for apps to be 4 GB, but I don't have a U30GT2 to test it, so I would need confirmation it's effective.
2/ Phone.apk is still installed, I leave removal option to the user, for example using this ArcTools package, ArcTools is preinstalled in the firmware, the procedure takes less than 30 seconds to do.
3/ I don't think this firmware is multi-user enabled, but I'll probably soon provide another ArcTools package to do that as well.
2013/06/13 - 21:46
I've just double checked the partition size for apps for the published firmware on post #1, it's quite likely that my calculation was based on 3 GB size, not 4 GB. Can anyone please confirm ?
If that's the case, I'll rebuild a firmware with 4 GB partition size right away.
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/13 - 21:48
I just installed it. How can i check. i give you answer right away.
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/13 - 21:52
At "Settings" - "Storage" i have Total Space in "Internal Storage" 1.97GB, "Available" 1.77gb "Apps" 109Mb "Chached Data" 19.16MB "Misc" 32kb
Nand Flash total space is 28.10 and apps 40.00kb and Misc 32.00kb
OBS: I just installed titanium backup so far.
2013/06/13 - 22:00
So it's 2 GB then Confused my apologies for that small mistake.
I've just rebuilt the firmware, it should be 4 GB for /data now.
Download: kasty-cube_u30gt2-422-203_20130606-rooted4.zip
I'll update post #1 once correct 4 GB size is confirmed, thanks for your feedback.
Iemand, Sync_One
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/13 - 22:01
I´m downloading (500kb/s - 15min, lol) it again to test for you :)
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/13 - 22:23
Total Space: 3.94
Available: 3.73
Apps: 69.77
Cached data: 756kb
Misc 16.00kb
* Nand Flash
Total Space: 26.13
Godo Work! :D
now fix HDMI Screen Time Out Please!!
:X
2013/06/13 - 23:06
Thanks for the confirmation, so it's 4GB now, post #1 updated.
I'll see if there is something I can do for the HDMI timeout...
68 Guest(s)
Devices in use: Desktop (64), Phone (4)
tdomnic024
otismaibe
Tsuna77
docentik2006
nechey
