[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.02 (2013/06/01)
cocoinasia
2013/06/04 - 09:33
Same boot issue. Black screen after, long push on power to solve and reboot. HDMI out works. Waiting for a fix please...
stassen
Sweden
Forum Posts: 62
Thanks Received: 43
2013/06/04 - 10:51
Test my rom i dont have that problem...
stassen
Sweden
Forum Posts: 62
Thanks Received: 43
2013/06/04 - 10:53
sharrman said
hi,
Very smooth ROM,  thanks.
BTW: sorry for the noob question but how do I set multi users? is it possible with this rom?
Ty again
It should be possible to enable multi-users like it is done on other tablets, check here:
http://www.arctablet.com/blog/forum/cube-u30gt2/cube-u30gt2-android-4-2-2-custom-root-firmware-beta-version-20130425/#p21808
I preferred not to enable it by default in our custom firmware as Cube may have some good reasons to do so in their stock firmware.
Still, I'm planning to make an ArcTools package to make it easier to set, I'll post when it's ready.
 Its by default in my rom :) chek it out!
Thanks Received: 3171
2013/06/04 - 11:33
I have just published a new ArcTools package that disables/moves the Phone.apk, this has been reported to save some battery life on the U30GT2.
vildkatt, fiji, flashkaisel, rayman
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/04 - 18:12
HDMI Screen Timeout still not working!
ANyone know a background solution?
Thanks.
uscool
Forum Posts: 11
2013/06/05 - 00:01
Hi, still the same , playing videos in browser full screen, just blank with sound
Uznamer
Poland
Forum Posts: 42
Thanks Received: 12
2013/06/05 - 01:03
fiji said
can anyone check the following that were still issues in the previous firmware (2.01):
1) distorted sound in skype
2) hdmi timeout does not work
3) no battery statistics
I have just installed your custom 2.02 rom. There was no problem with booting at all. Flashing went quite smoothly.
I have checked all three mentioned issues and got following results:
1) fixed
2) not fixed
3) not fixed
I have noticed also that Chrome browser is working very smoothly now without any lagging. Not enough time yet to say more about this new FW. Thank you admin very much for your nice and quick job!
The following users say thank you to Uznamer for this useful post:
fiji
ericb
Forum Posts: 12
2013/06/05 - 17:04
I went back to 2.01 because i keep black screens after Arctablet logo
Sometimes it will boot normally and then again black screen.
Did not test is i have same issue with official Cube 2.02 firmware, anyone did??
florfilla19
France
2013/06/06 - 13:00
Hello, First of all. Thanks for all of the time you spend on creating and modifying firmwares youre great !
All testing are made on my cube u30gt2 v3 (freshly received):
-I tried different firmware last night : first 1.05 with 4.1.1 and then2.02w 4.2.2 and antutu benchmarks score are poorest on the newest version. Is this a normal issue ?
Is there any difference in scores between 2.01 and 2.02 ?
-I noticed wifi is very sensitive on 1.05 firmware can the newest release can bring more stability ?
Thanks again for all of you
fiji
Greece
Forum Posts: 20
Thanks Received: 4
2013/06/06 - 13:16
I have the tablet two months now and i have concluded the following..
1.03 version which was the one that came with the tablet as stock, sucked hard...
At first i skipped 1.05 and went directly to all the betas 4.2 that came out. Then i tested the arctablet rooted versions of the released 4.2.
All of the 4.2 versions give a significantly lower Antutu score. in average 4.2 gives you aroun 15.000 - 15.200 mark. As said in previous posts benchmarks are not always a rule to choose whether a firmware is good or bad. Our tablet performs worse in gaming with 4.2 in real life for sure, not so much worse but it lags a bit more.
In 4.2 the touch screen though is more sensitive and accurate lets say (checked with multitouch testers) but there are issues also with a sort of flickering (an automatic increase decrease in the brightness for no reason)
The wifi was awful in 1.03, was better in 1.05 and is more stable in 4.2
4.2 also has issues with the battery, which were partly solved with removing the Phone.apk
In 4.2 you will find issues with the hdmi timeout and your battery statistics (skype was fixed in the last 4.2 2.02 thankfully)
Concluding and always in my own opinion the best firmware for now is still 1.05. The laptop is a bit faster in general than any other firmware (not so smooth touch as 4.2 though), and if you don`t experience problems with your WiFi then its the one to go... Until 4.2 issues are resolved
The following users say thank you to fiji for this useful post:
florfilla19, ecki2k, osya13
fiji
Greece
Forum Posts: 20
Thanks Received: 4
2013/06/06 - 13:26
Same here, i get random hangs after the arctablet logo. Went back to 1.05.
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/06 - 15:24
This randoms black screen hangs really fucks up the beauty of this rom... hehe
i hope its fixed soon enough :(
DarthJabba
Forum Posts: 551
Thanks Received: 396
2013/06/06 - 17:27
@admin: I would like to propose that space for apps storage (i.e., the /data partition) should be set at 4GB. The default 2GB will eventually turn out to be too constraining, and I am not sure that one can increase its size after installing the firmware.
Thanks.
2013/06/06 - 17:36
That makes sense to me, what do others think ? Wink
vildkatt, ecki2k
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/06 - 17:39
I´m neutral, since i don´t have a clue about what you guys are talking about
/o\
75 Guest(s)
Devices in use: Desktop (66), Phone (9)
rk.13
siwinfi64
dangphat
dpc
ngu
