[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.01 (2013/05/26)
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
61
2013/05/31 - 20:41
Magnifico said
To sum it up.
Take the last download to install a CWM Recovery 6.0.3.1 WITHOUT a hassle.
Then you use Reboot-tool or whatever to enter the newly installed CWM.
NOW you can flash the Radio-Fix posted before. 100%!!!
When i start RKAndroidTool v. 1.37 from this file it says Found RKAndroid Mass Storage USB than i click Run or EraseIDB and i get this error: "MSC device can´t do upgrade"
Any1 know how to fix this??
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
62
2013/05/31 - 21:00
i give up.. lol
Magnifico
Forum Posts: 25
63
2013/05/31 - 23:51
I said behave as I you were flashing a firmware!!!!!
YOU DON´t FLASH FIRMWARE IN MASS STORAGE MODE....jeeeezzzz
So push that damn "switch" button to get into flash mode.... :rolleyes:
Thanks Received: 264
64
2013/06/01 - 02:00
marcobus2005
Forum Posts: 18
65
2013/06/01 - 08:50
hi everybody,
I've installed cwm without problem, but impossible to update with the mod by JellyBelly.
each time I get "update aborded"
Is there a solution to fix this issue?
Thx
DarthJabba
Forum Posts: 551
Thanks Received: 396
66
2013/06/01 - 10:14
You might want to report whatever else was on the screen.
marcobus2005
Forum Posts: 18
67
2013/06/01 - 10:29
ok.
I start my tablet in CWM mode.
I select "apply update from external storage
I select "jellybellys-mod-wifionly-2.zip"
I see on the screen:
Recovery system v4.201
--- Install /mnt/external_sd.....
Finding update package...
Opening update package...
Verifying update package...
Installation aborted.
That's all....
I 'm using the last firmware (05-26-2013).
Have I to install just after flashing rom? Because here my tablet has a lot of app already installed. These maybe cause the issue...
Thx
stassen
Sweden
Forum Posts: 62
Thanks Received: 43
68
2013/06/01 - 13:14
Can somone upload this to sam other place http://uploaded.net/file/9ugkaxhj
Bless
marcobus2005
Forum Posts: 18
69
2013/06/01 - 14:29
Hi Stassen,
I've uploaded here: http://wb4hkn.1fichier.com/
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
70
2013/06/01 - 14:54
When i use the swtich button and try to flash.. it says MSC Device can´t update..
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
71
2013/06/01 - 14:56
EDIT: When i use the switch it goes to "No Found RKAndroid rock usb" and screen goes off. What now??
Magnifico
Forum Posts: 25
72
2013/06/01 - 15:15
Since you obviously are unable to flash a firmware you should stay away doing anything other than normal usage with that device.
Will be better to stop here before you break your device.
@marcobus: READ more carefully! I said that CWM Recovery V6.0.3.1 will be installed!
You need to the flash the CWM Recovery packacke first! (Successfully obviously...)
Then you can use the Zip file for the radio fix.
The non stock Recovery looks CLEARLY different to the stock one. Gray background for example...
Guys alltogether! Read more carefully and more important do as requested! Otherwise you will possibly break your device which will be hard to fix if possible in the first place.
The following users say thank you to Magnifico for this useful post:
ecki2k
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
73
2013/06/01 - 15:19
Thanks for the support. you R0CK!
fucker!
Magnifico
Forum Posts: 25
74
2013/06/01 - 15:24
fucker!
THANKS!
marcobus2005
Forum Posts: 18
75
2013/06/01 - 15:26
@magnifico:
CWM is installed otherwise i could'nt use update from external storage....
71 Guest(s)
Devices in use: Desktop (62), Phone (9)
Shincozen
karim78190
mario millan
estelavg
Skyzhay
HorstG
