[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.01 (2013/05/26)
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
46
2013/05/31 - 18:22
How can i install CWM recovery?
:X
BapeBape
Forum Posts: 23
47
2013/05/31 - 18:22
Perhaps there is a confusion with another comment from another Mr. Wonderful which reads as follows:
Here is the ZIP: http://ul.to/hai7ld8b
Just download and install / flash it in CWM Recovery and everything is fine.
As said .... some elso DarthJabba created this .... so thank him if u find the original source
thanks
With the program ESFileExplorer prmite I remove these instructions.
Neither allows me to rename
thanks
DarthJabba
Forum Posts: 551
Thanks Received: 396
48
2013/05/31 - 18:23
You must have CWM Recovery installed on your tablet. If you have CWM, then just copy the zip file to the sdcard, boot into recovery, select "install from zip", select the jellybelly zip file, and confirm that you want to install it. That is all you need.
If CWM is not installed, then you cannot apply this mod as it is. You will have to delete or rename the files manually, using ESFileExplorer, etc., as explained above.
BapeBape
Forum Posts: 23
49
2013/05/31 - 18:31
I install CWM? ....
With the program can not get rid ESFileExplorer these file. Cos I can not rename files to remove
thanks
DarthJabba
Forum Posts: 551
50
2013/05/31 - 18:31
:X
There are CWM recovery packages for RK3188 tablets here. You should be able to install it using the stock recovery.
There are some instructions here.
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
51
2013/05/31 - 18:32
Don´t you (anyone else) can help me install CWM Recovery :X ?
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
52
2013/05/31 - 18:35
DarthJabba said
:X
appreciate!!
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
53
2013/05/31 - 19:05
When i´m trying to apply the zip file (CWM Recovery file) it starts to install but after opening, veryfing.. it says "Installation aborted".. anyone know why? and how to fix?
Magnifico
Forum Posts: 25
54
2013/05/31 - 19:07
I´m not shure they know what STOCK RECOVERY is.
Or do they how how to get there...
Power Off. Press and hold Volume+ and now press Power. Hold that until you see screen (anything).
Or much much easier....use a reboot tool to boot to recovery.
DarthJabba
Forum Posts: 551
55
2013/05/31 - 19:22
BapeBape said
I install CWM? ....
thanks
You first have to mount "system" as "rw" (i.e., read and write).
Magnifico
Forum Posts: 25
56
2013/05/31 - 19:28
Or just download this: http://uploaded.net/file/9ugkaxhj
...and behave as if you were flashing a rom.
don´t worry...nothing is lost if you do it right
/EDIT: This thing worked for EVERY Rom release until today and I didn´t need to a change a thing!
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
57
2013/05/31 - 19:30
that error i got was into recovery stock mode.. the installation aborted.. :/
Magnifico
Forum Posts: 25
58
2013/05/31 - 19:34
See post #56
lambo2000
59
2013/05/31 - 19:35
I had the problem with chrome too, but it seems like I can use Dolphin Browser without problem.
uscool said
Hi, just tried this , still cant play flash in full screen with stock browser, i really like watching BBC iplayer site in HD, also youtube desktop site doesnt work in full screen, and it worked in version 4.1.1 , thought this release not beta anymore would be working now :(
Magnifico
Forum Posts: 25
60
2013/05/31 - 19:36
To sum it up.
Take the last download to install a CWM Recovery 6.0.3.1 WITHOUT a hassle.
Then you use Reboot-tool or whatever to enter the newly installed CWM.
NOW you can flash the Radio-Fix posted before. 100%!!!
71 Guest(s)
Devices in use: Desktop (64), Phone (7)
Shincozen
karim78190
mario millan
estelavg
Skyzhay
HorstG
