[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.01 (2013/05/26)
BapeBape
Forum Posts: 23
31
2013/05/31 - 12:14
Low battery duration with v 4.2.2 (01)
I have the impression that the battery consumption is skyrocketing, if comporamos this version (4.2.2 rot 3) with the latest version 4.1.1. The difference in length is important, bearing in mind to take the steps to ensure that the recharge cycle was from 0%.
Regards
Spain
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
32
2013/05/31 - 14:37
Yeah, battery suxs now!
The following users say thank you to Sethi for this useful post:
BapeBape
DarthJabba
Forum Posts: 551
Thanks Received: 396
33
2013/05/31 - 16:18
It is the ringer/phone radio that is eating up the battery. There is a mod by JellyBelly (probably posted somewhere on this forum) that removes all the unnecessary telephony stuff. This will restore battery life to normal. You need CWM recovery to install it. It is discussed on this page.
BapeBape, thatoneguysomeplace
BapeBape
Forum Posts: 23
34
2013/05/31 - 16:48
You are assured that you can apply to U30GT2 Cube tablet?
thanks
DarthJabba
Forum Posts: 551
35
2013/05/31 - 17:09
Yes, I install it every time I upgrade my firmware. The mod deletes these apk files;
/system/app/Messaging.apk
/system/app/Phone.apk
/system/app/TelephonyProvider.apk
/system/app/TelocationProvider.apk
/system/app/Mms.apk
If you don't have CWM, then there has been a suggestion to use ESFileExplorer or similar app to mount "system" as "rw" and rename those files. That way, the change is reversible.
DarthJabba
Forum Posts: 551
36
2013/05/31 - 17:12
PS: "admin" could probably remove these apk files from future firmware releases - then one doesn't need to find a way of removing them.
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
37
2013/05/31 - 17:14
Me neither, if anyone can help how to fix the battery issue, i would appreciate : )
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
38
2013/05/31 - 17:17
/system/app/Mms.apk
How can i mount System as RW? :X
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
39
2013/05/31 - 17:25
I used: https://play.google.com/store/apps/details?id=com.beansoft.mount_system&hl=pt_BR to mount the system file but i couldn´t find the Messaging.apk and TelocatoinProvider.apk
Deleted the other 3 files. hope battery life increases a little :/
BapeBape
Forum Posts: 23
40
2013/05/31 - 17:25
I get friend. I managed to disable the ringing phone and a recommended program "Smart Quick Settings". I'm going to delete:
/ system / app / Messaging.apk
/ system / app / Phone.apk
/ system / app / TelephonyProvider.apk
/ system / app / TelocationProvider.apk
/ system / app / Mms.apk
  Thank you very much
Magnifico
Forum Posts: 25
41
2013/05/31 - 17:46
Here is the ZIP: http://ul.to/hai7ld8b
Just download and install/flash it in CWM Recovery and everything is fine.
As DarthJabba said....some elso created this....so thank him if u find the original source ;)
BapeBape
Forum Posts: 23
42
2013/05/31 - 17:52
With this program jellybellys-mod-wifionly-2 are put into effect all previous operations?
thanks
Magnifico
Forum Posts: 25
43
2013/05/31 - 18:00
Darth Jabba just did tell what this zip does. Nothing else.
You can check if it was successful (see screenshot).
The mobile signal should turn from red to this ugly yellow.
Screenshot_2013-05-31-17-57-28.pngImage Enlarger
DarthJabba
Forum Posts: 551
44
2013/05/31 - 18:02
thanks
Sorry, but I do not understand what you mean. But I can confirm that the mod does not seem to affect anything else (i.e., I believe that it is safe).
BapeBape
Forum Posts: 23
45
2013/05/31 - 18:10
Excuse my ignorance. Now I have the zip file. Unzip ..... and where I have to leave (installed) to produce the desired effect
Using the program, allow me to remove these instructions:
/ system / app / Phone.apk and other
thank you very much
165 Guest(s)
Devices in use: Desktop (156), Phone (8), Tablet (1)
jacklewis3
123456asd
valdes1964
pipo2015max
Vickyabc
massoud
