Here is an Android 4.2.2 Jelly Bean rooted firmware for the Cube U30GT2 tablet based on latest Cube official update version 2.01 released 2013/05/26
(CUBE U30GT2_V2.01_Android4.2.2_20130526.rar)
Kernel: Linux version 3.0.36+ (lcp@tchip-super) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #29 SMP PREEMPT Sun May 26 20:31:26 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.lcp.20130523.191215:eng/opinions-on-teclast-p90hdst-keys
According to the manufacturer, this firmware brings the following changes (Google Translate from Chinese):
1 further improve the software and hardware compatibility;
2. optimize overall system operation fluency, enhance the user experience.
- root with latest SuperSU version 1.30 (free version)
Download: kasty-cube_u30gt2-422-201_20130526-rooted3.zip
Please flash with Rockchip Batch Tool 1.6, use Restore button.
Baeckman, Reini, pribi, Bsoft2007, sipdude, nefsim, vildkatt, robiom, u30gt2Owner, Goldi6, thatoneguysomeplace, Grigory, geloczigeri, angstcr, fana75 If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
The best thing to do is flashing with Rockchip Batch Tool 1.6 and use Restore button while flashing to make sure the tablet gets properly erased.
We have 3 mirrors on our servers that should provide reasonable download speed for most part of the world, please don't mirror our files.
2013/04/16
2013/05/02
Restore vs Upgrade is like Windows setup.
Upgrade keeps existing data and just replaces systemfiles, restore aims to "restore" your chosen image by erasing the internal memory and then installing the rom.
Upgrade can work (will, probably, in this case of just slightly altered betas) but there´s much that can go wrong.
To be on the safe side you should do "restore"; that´s also the only way to be sure any occuring problems are really bugs and not faulty installation.
You can always back up all your userapps+their data data using titanium backup and, after clean install of new rom, restoring them. 3-4 clicks and youre done.
The following users say thank you to ecki2k for this useful post:
admin, thatoneguysomeplace, vildkatt
2013/05/02
Just installed the new firmware. There is a new wallpaper So running antutu now, will post the results right away. @Admin did you forget the little chiming sound in the loading screen ?
just kidding..
Antutu finished running the score is 15200 so again better than the last beta that scored 15080.
Will install other apps now and check.
2013/04/30
When i am really close to the router and no devices are connected to the same wifi...i get good connection speed of 12mbps...but when i go away from it and if a few devices are connected then my wifi router speed goes down to 2mbps...do you guys think it is hardware or software problem or a problem with my router?
thank you for ur help
Currently Online: dangerosu74
63 Guest(s)
Devices in use: Desktop (56), Phone (8)
