[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware final 2.04 version (2013/08/10)
kaloyan
481
2013/10/27 - 13:17
Farscape1 said
Its listed as a test firmware.
Been running for a couple of days now.
For me its a very good one, even with the oc kernel installed.
Battery life is much improved. Was getting at best 8hrs on all v2.04 firmware.
v2.06 is giving me 2 days including some browsing etc.
You dont have to have multiwindow enabled to get the previous apps to work.
Overall its a very nice update and fixes the niggles that were present in v2.04.
Thank you Farscape1, for the detailed reply. Which version do you refer to: originally posted in Cube website or kasty-cube_u30gt2-422-206t_20131017-rooted4?
Farscape1
Forum Posts: 24
Thanks Received: 17
482
2013/10/27 - 18:07
Kayolan.
This is the pre multi window one.
Kasty:[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware version 2.04 test version (2013/07/06)
Or the original direct from cube
http://bbs.51cube.com/forum.php?mod=viewthread&tid=73641&mobile=yes
The v2.06 firmware, i knocked one up myself.
But originally tested kasty v2.06 rom to see if it was any good.
Was pleasantly surprised when things worked properly.
The following users say thank you to Farscape1 for this useful post:
kaloyan
Oyeee
Forum Posts: 11
Thanks Received: 9
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
484
2013/11/02 - 02:02
Please take a moment to visit this conversation regarding the possible changing of the Arctablet logo;
http://www.arctablet.com/blog/forum/cube-u30gt2/updateupgrade-of-the-arctablet-logo/
Thank you
twart
Liverpool
Forum Posts: 24
Thanks Received: 17
485
2013/12/12 - 12:56
I know this has been covered many times before. I have upgraded many devices to custom ROMs in the past, but I felt the documentation here was a little lacking. So, when I eventually figured out all the tools I needed, the steps were pretty straightforward. So I documented them and they follow here.
I started with a stock Cube U30GT2 device, stock F/W 2.03 installed out of the box. I was running this from Windows 7 64Bit.
You will need:
  • Rockchip Batch Tool v1.7
  • Rockchip Drivers v3.5
First step - ensure your device is charged.
  • Connect device - it should be recognised standard USB connection.
  • Start 'Rockchip_Batch_Tool_v1.7\RKBatchtool.exe'
  • Device should show as connected (1).
  • Click Switch (device screen will go black)
  • If it fails installing drivers (it should):
  • On Windows, click Start/Run, enter 'devmgmt.msc'
  • Find the unknown device
  • Right-click, choose 'Update Driver'
  • Choose to find the driver yourself.
  • Navigate to 'Rockchip_Batch_Tool_v1.7\RockusbDriver'
  • Ensure Subfolders is checked and choose to install.
  • Confirm install
  • When complete, check RKBatchTool again - the device should now show as connected. If not, reboot the device (holding power for 5-10 secs, may have to do this twice) then start these instructions again.
  • Extract the ROM zip (currently kasty-cube_u30gt2-422-204_20130810-rooted4c.zip, should extract to update.img)
  • Load the new rom ('...' next to FW Path, choose update.img)
  • Click Restore
  • Log will display in the window similar to the following:
 **********Restore Action**********
 **********Restore Start Total<1>**********
 <Layer 2-1-1> Test Device Start
 <Layer 2-1-1> Test Device Success
 <Layer 2-1-1> Lowerformat Device Start
 <Layer 2-1-1> Lowerformat Device Success
 <Layer 2-1-1> Check Chip Start
 <Layer 2-1-1> Check Chip Success
 <Layer 2-1-1> Get FlashInfo Start
 <Layer 2-1-1> Get FlashInfo Success
 <Layer 2-1-1> Prepare IDB Start
 <Layer 2-1-1> Prepare IDB Success
 <Layer 2-1-1> Download IDB Start
 <Layer 2-1-1> Download IDB Success
 <Layer 2-1-1> Reset Device Start
 <Layer 2-1-1> Reset Device Success
 <Layer 2-1-1> Wait For Loader Start
 <Layer 2-1-1> Wait For Loader Success
 <Layer 2-1-1> Download Firmware Start
 <Layer 2-1-1> Download Firmware Success
 **********Restore Done Success<1> Fail<0> Time<158309>ms**********
  • When complete (<1m) device will reboot.
  • Device will display as Recovery, with a Lloyd Android with a belly full of icosohedrons (I think...)
  • Device displays:
 Recovery
 Formatting /data
 Formatting /cache
 Formatting /mnt/sdcard
  • (takes around 2m)
  • Device reboots again
  • Now you will see an ArcTablet splash logo, followed by a different animated chinese startup logo.
  • Device will take much longer to boot - around 2-3m rather than 1m. This is normal on first boot after upgrade.
  • When device starts, it will be in new device help mode, showing you how to start apps.
About the ROM:
Apart from a little slow-down when starting the device after the upgrade, everything seems smooth. The Multi-window operates well, although the help is pretty atrocious. Again, if it helps at all, my version of how to use the functionality follows:
Multi-window can be enabled in settings.
A new button appears on right (can be moved by dragging it) which allows you to set the apps into different layouts:
  • 2-win - 2 side-by-side resizeable windows
  • 4-win - Overlaying Floating windows
  • Full-screen - normal
2-win mode.
  • Click on a window enables it.
  • The white bar in the center can be dragged right and left to increase/decrease the size of the windows.
4-win mode.
  • Editing the size/position of the window can be enabled by putting 3 fingers in the window a dragging down sharply. Window will ghost.
  • Single-finger drag to new position
  • Pinch-zoom to change size
  • 3-finger drag up to fix position/size.
All modes:
  • Any application should have a new title-bar button on the top right, to allow changing the app to 1-,2- or 4-win mode.
Here's looking forward to 2.06
"If I wanted your opinion, I'd give it to you"
t.w@ - Battling whinge-bags since '71
Currently Online: WhiteD2125
65 Guest(s)
Devices in use: Desktop (62), Phone (4)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
