validatus said
Please someone
what apk for editing build.prop
or what procedure
thanks
Just type in the search bar on google play for " build.prop editor" and you will find enough results, remember that you need root to be able to edit your build.prop.
2013/07/07
This update follows our recent custom firmware modifications to fix the keyboard problem.
Here is the v2.04 firmware update final version for the Cube U30GT2 built on RK3188 SDK2.0 and providing multi-windows feature. This firmware is published on Cube official website with 2013/08/10 release date.
(U30GTĺ››ć ¸č±Śč±†2_V2.04_20130810.rar)
Build information:
Kernel:Â Linux version 3.0.36+ (lcp@tchip-super) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #37 SMP PREEMPT Sat Aug 10 10:07:29 CST 2013
Android 4.2.2 Jelly Bean:Â rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.lcp.20130801.194246:eng/opinions-on-teclast-p90hdst-keys
Cube U30GT2 firmware revision history (Google Translate from Chinese)
- An increase HD / puqing double resolution display mode;Â
- increasing multi-window function, take advantage of quad-core ultra-high-definition screen peas 2;Â
- increasing state native HDMI output loud speaker mute function;Â
- optimize key boot time;Â
- to increase multi-partitioned external storage device identification;Â
- optimize the audio driver, the audio output is more stable;Â
- the depth of speed, the system run more smoothly.
- root with latest SuperSU version 1.51 (free version)
- firmware download comes in two versions: stock recovery or CWM recovery (courtesy androtab.info)
- increased storage space for applications (/data partition) to 4 GB, firmware with CWM Recovery has 2 GB storage space for apps
- NEW! kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma & Crew RKTablets, thank guys!
- Android keyboard from Cube U30GT2 previous firmware
Download:Â
(stock recovery) Â kasty-cube_u30gt2-422-204_20130810-rooted4c.zip
(CWM recovery)Â kasty-cube_u30gt2-422-204_20130810-cwm_rooted4c.zip
Please download stock recovery version if you are not sure which one to choose.
Flash the firmware with Rockchip Batch Tool 1.7,  use Restore button.
thank you for posting this versions!!! I was very tired late yesterday so I couldn't try much, but so far ROM felt faster then previous test versions. I tried some use with multiple windows, but I don't think it's that useful and it's again more like marketing gimmick from Rockchip. I will check tonight if VPN apps will work due to new kernel. Oh, and I am still getting blank screen on place of recovery Â
Have you tried to push the recovery via adb ?
The vpn will not work if the tun.ko module is not present.
2013/06/15
this is the link to the u30gt2 cube51 untouch version ?
2013/07/09
So, I havnet flashed yet. I was wondering, "Do i want the CWM version or the other version" Whats the difference here really. What should I consider when picking one over the other? I like the idea of 4gig ram, but I also would like the cwm if its really a tool I can use. Help me out?Â
2013/08/03
Have you got CWM installed? if not you need the other version.
I'm on the official version and I want to go back as it's full of bugs.
Is it best to chose the "upgrade" or "restore" button?
2013/04/26
I think I'll have to go back to the previous version as this one is terrible for playing HD video, in a window OR full screen. I've tried several different players and have had similar results with them all.
Before I re-flash, was there a bug fix release dated 2013.08.15Â (@eeprom's post??)??
Rob
EDIT: Should always check first duh! File is for the latest version we have now!
You will not have 4Gb RAM, you will have 4 Gb space dedicated for app instalations (stock is 2 Gb i think)
Please do google what is CWM, in this way you will find out if you need the CWM version.
maikal
2013/07/09
___________________________________________________________________________________________________________________________
Okay, I did the CWM research and decided I would go with that version. When I got it all flashed I did notice that internal storage is 1.97gb, available is 1.53gb after installing my apps. In the previous rom I clearly had 4gb to start of with, give or take a few for the system stuff. Nand card clearly back up to the 28+gb space where before flashing it was less do to the added internal gb.
I like the idea of the CWM, but it seems I have less with this vesion than with the previous version. Am I right or am I missing something here, which is possible as I am such a newb here...lol
2013/06/19
Just flashed.working grand, just needs some time to settle, I don't see the point in cwm, I mean I can do everything I need with stock, why do u need it, u can't flash through it, so what's the point, I think keyboard is a little insesitive, will install Google keyboard newest version
77 Guest(s)
Devices in use: Desktop (66), Phone (10), Tablet (1)
makaryura
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
