[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware final 2.04 version (2013/08/10)
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
2013/08/14 - 03:46
Okay, am ready to cry with confusion. Can someone who flashed cwm rom give us a report?
val532
2013/08/14 - 04:24
Hi
This rom is good, but now i have two black barre, one on the top and one on the botom.
How i can make only one barre ? (on the botom of screen)
Sorry for the bad english i'm french.
robiom
Norwich, UK
Advanced Member
Forum Posts: 124
Thanks Received: 27
2013/08/14 - 08:34
Great work yet again @admin, much appreciated.
Rob
newbi
Forum Posts: 46
2013/08/14 - 08:42
Thanks for your help guys I installed Chrome bookmark widget and all is ok.
I must though the old way of saving web pages was much easier.
AndyDir87
Germany, Bavaria
2013/08/14 - 09:00
val532 said
Hi
Best wishes to my neighboring country!
I'm using full!screen app to remove the bar (here: both bars) and TEAM Battery Bar to have back a slim battery indicator on bottom of the screen.
This combination looks great to every tablet. In my mind.
robiom
Norwich, UK
Advanced Member
Forum Posts: 124
Thanks Received: 27
2013/08/14 - 10:57
@admin, I noticed the kernel has been customised, does this mean we will be getting some more customised features like overclocking??
Rob
Thanks Received: 3177
2013/08/14 - 11:08
Rob,
The kernel included in the firmware is the stock one from Cube, we've just added some kernel modules compiled by our friends Oma & Crew RKTablets to provide extra functionality like VPN, joystick support,...
These modules aren't loaded by default, they can be activated thru init.d scripts. There is also some support thru ArcTools, but it's not finished and fully documented yet.
Still there is no overclocking for the U30GT2 at the moment.
robiom
Tjilie
Thanks Received: 5
2013/08/14 - 11:47
AndyDir87 said
val532 said
Hi
You can use the following lines in build.prop
* for split top-notification bar: set ro.rk.systembar.tabletUI=false
* for bottom-notification bar: set ro.rk.systembar.tabletUI=true
The following users say thank you to Tjilie for this useful post:
geloczigeri, robiom, vlevi, csjanne, francsal
geloczigeri
Hungary
Thanks Received: 5
2013/08/14 - 12:30
Tjilie said
AndyDir87 said
val532 said
Hi
Saved my life, thanks :)
AndyDir87
Germany, Bavaria
2013/08/14 - 14:12
Rob,
I have here one U30GT2 kernel which makes the Cube supporting USB hubs. But I don't know how add or update this.
If someone else want to have his Cube supporting USB hubs, I could share this kernel.img. Maybe there is a possibility to add this module (if this is a module?) to the next future built?
The following users say thank you to AndyDir87 for this useful post:
robiom, 080200, thatoneguysomeplace
2013/08/14 - 16:37
AndyDir87,
The firmware for Chuwi V88 (RK3188 tablet) by Oma and Crew RKTablets is mentioned to be USB-Hub enabled. I am not sure if this is done thru a custom built kernel or kernel modules, you can ask Oma in RKTablets forum section.
If it's a kernel module, it should already be included in our custom firmware, as the modules in this custom firmware just come from Oma and Crew RKTablets, they'll just need to be loaded thru insmod.
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
2013/08/14 - 17:03
Please someone
what apk for editing build.prop
or what procedure
thanks
deinemudda24
Forum Posts: 11
2013/08/14 - 17:18
Big thanks and much props. Working like a charme.
zedcool
2013/08/14 - 18:32
hi i'm new here, i had the first u30gt and i bought the second version u30gt2 4.2 but i have problem with the wifi (very week). i would like to install this version but my tablet is not rooted and i don't know how to install this version. do you have a simple tuto wich can explain to me ?? excuse my bad english i'm french
thank you
peteus
Forum Posts: 47
Thanks Received: 9
2013/08/14 - 19:18
Tjilie said
AndyDir87 said
val532 said
Hi
Thanks for the solution. However, I would like to mention that having 2 bars on your tab is not a mistake. Few months back, Google decided to unify Android UI and therefore tablet UI is now the same as smartphone UI. for example, Google (search) "new nexus 7" and see screenshots. I as well liked previous tablet UI, especially easily reachable back button positioned in left corner.
Currently Online: Stellar7, WhiteD2125
105 Guest(s)
Devices in use: Desktop (70), Phone (37)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
