[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware final 2.04 version (2013/08/10)
pvsantos
Forum Posts: 12
166
2013/08/27 - 10:57
pbenaim said
For the CWM don't use this one is buggy, black screen :-(
Use this one, working well RK30GENERIC_CWM.zip
Tested this CWM yesterday and it worked on the released rom from 1st post, CWM6.0.3.1 if not mistaken. Thanx for the tip.
Ill try the 4GB release rom later on too. Ty all and keep it up.
Lets hope Rockchip and Cube release their sources or improved firmware at least, so we can get or tablet to a stable condition.
The following users say thank you to pvsantos for this useful post:
maikal
Farscape1
Forum Posts: 24
Thanks Received: 17
167
2013/08/27 - 12:48
maikal said
I'll be happy to give it a go admin. Will u be trying for a 4 or 2 GB cwm version?
Here is a new build with 4 GB storage space for apps and this CWM Recovery RK30GENERIC_CWM.zip  (by fun_ / androtab.info)
Download: (CWM recovery) kasty-cube_u30gt2-422-204_20130810-cwm_rooted4d.zip
Tested and working. No black screen. Booted straight to cwm.
First one of your roms with cwm that actually works on my tablet.
Thank you.
The following users say thank you to Farscape1 for this useful post:
admin, maikal
Thanks Received: 3177
168
2013/08/27 - 13:01
Thanks for your feedback Farscape1, I'm update post#1 with this version of the firmware.
From now on, I'll use that CWM recovery on future firmware builds.
Farscape1
Forum Posts: 24
Thanks Received: 17
169
2013/08/27 - 13:43
Uznamer
Poland
Forum Posts: 42
Thanks Received: 12
170
2013/08/27 - 13:43
@admin. I have flashed this new CWM rom and got a sdcard unmounted. I was flashing it twice. First time after flashing I pushed power button twice and system immediatelly has been rebooted. Second time I used CWM options, it means I formated sdcard and mounted it. After rebooting I got again the same: unmounted sdcard. In settings I touched " Mount SD Card" but it does nothing. Just blinking shortly witout required action. What should I do to mount it?  By the way, external SD card is mounting automatically without any problem.
Farscape1
Forum Posts: 24
Thanks Received: 17
171
2013/08/27 - 13:46
Thank you.
Just out of interest.
I know its upto us to remove what we dont want.
But the following are redundant files found in the system/lib/ folder.
libiReader_common.so
libiReader_ebk3parser.so
libiReader_epubparser.so
libiReader_filezip.so
libiReader_icu.so
libiReader_txtparser.so
libjni_pinyinime.so
libsohuplayer_jni.so
libsohuvideo7_jni.so
libsohuvideo8_jni.so
libsohuvideo14_jni.so
libZxlSo_cn_kuwo_player_360352.so
libZxlSo_com_baidu_hao123_550343.so
libZxlSo_com_sohu_sohuvideo_270481.so
libZxlSo_cn_ninegame_gamemanager_30476.so
libZxlSo_com_yingyonghui_market_320169.so
maikal, admin
Farscape1
Forum Posts: 24
Thanks Received: 17
172
2013/08/27 - 13:50
After flashing it boots to cwm.
Reboot to android. Once it has finished loading. Goto settings then storage and mount sd.
It will say top left preparing storage. Pull down the top left, click it and it will say format sd.
Uznamer, admin
Uznamer
Poland
Forum Posts: 42
Thanks Received: 12
173
2013/08/27 - 14:05
@Farscape1. Thank you very much, mate! It was funny easy, my fault that I did not notice small information at the left top of screen. Now everything is OK. SD Card mounted duly and I can go further with all necessary instalations.
maikal
Jacksonville, Florida
Forum Posts: 394
Thanks Received: 51
174
2013/08/27 - 14:07
I see am late to the test, and I am at work now, so I will try it later and report also.
DarthJabba
Forum Posts: 551
Thanks Received: 396
175
2013/08/27 - 14:17
libiReader_icu.so
libjni_pinyinime.so
Are you sure that no application (e.g., ebook readers, text editors, file managers) will require any of those "libiReader*" libraries?
Farscape1
Forum Posts: 24
Thanks Received: 17
176
2013/08/27 - 14:43
Have had no issue with removing them. iReader was a Chinese system app in previous firmware.
It was not in the 10.08.13 stock firmware, i already tested and have had no problems.
I use xplore as my file manager and moonreader pro for reading etc.
The rest of the .so files are related to the Chinese apps that have been removed.
DarthJabba, admin, maikal
Farscape1
Forum Posts: 24
Thanks Received: 17
177
2013/08/27 - 14:52
Still have issues with G5 games not working properly.
Get sound but nothing else.
Change screen to sd mode does not help.
The only way i can get them to work is to replace the build.prop from 06.06.13
For reference:
Bigfoot and epic adventure Lajangade
Any ideas would be appreciated.
178
2013/08/27 - 14:56
Thanks for your suggestion Farscape1.
I'll double check as well and will probably remove these files in the next custom firmware build.
validatus
Advanced Member
Forum Posts: 180
Thanks Received: 18
179
2013/08/27 - 15:06
Hello
is there some guy to help me
how to go back the rom wallpaper
is it possible to use multi user
 please
really i am not a specialist
perhaps buildprops
DarthJabba
Forum Posts: 551
180
2013/08/27 - 15:25
For reference:
Possibly a missing video codec?
Currently Online: Stellar7, WhiteD2125
102 Guest(s)
Devices in use: Desktop (67), Phone (37)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
