This update follows our recent custom firmware modifications to fix the keyboard problem.
Here is the v2.04 firmware update final version for the Cube U30GT2 built on RK3188 SDK2.0 and providing multi-windows feature. This firmware is published on Cube official website with 2013/08/10 release date.
(U30GT四核豌豆2_V2.04_20130810.rar)
Build information:
Kernel: Linux version 3.0.36+ (lcp@tchip-super) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #37 SMP PREEMPT Sat Aug 10 10:07:29 CST 2013
Android 4.2.2 Jelly Bean: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.lcp.20130801.194246:eng/opinions-on-teclast-p90hdst-keys
Cube U30GT2 firmware revision history (Google Translate from Chinese)
- An increase HD / puqing double resolution display mode;
- increasing multi-window function, take advantage of quad-core ultra-high-definition screen peas 2;
- increasing state native HDMI output loud speaker mute function;
- optimize key boot time;
- to increase multi-partitioned external storage device identification;
- optimize the audio driver, the audio output is more stable;
- the depth of speed, the system run more smoothly.
- root with latest SuperSU version 1.51 (free version)
- firmware download comes in two versions: stock recovery or CWM recovery (courtesy androtab.info)
- increased storage space for applications (/data partition) to 4 GB
- NEW! kernel modules (cifs, tun, lan, serial, xpad) compiled by Oma & Crew RKTablets, thank guys!
- Android keyboard from Cube U30GT2 previous firmware
Update 2013/08/27: fixed CWM Recovery version, now with 4 GB storage space for apps.
Download:
(stock recovery) kasty-cube_u30gt2-422-204_20130810-rooted4c.zip
(CWM recovery) kasty-cube_u30gt2-422-204_20130810-cwm_rooted4d.zip
Please download stock recovery version if you are not sure which one to choose.
Flash the firmware with Rockchip Batch Tool 1.7, use Restore button.
For CWM recovery update, after flashing it boots to CWM. Reboot to android. Once it has finished loading, Go to Settings then Storage and mount sd. It will say top left preparing storage. Pull down the top left, click it and it will say format sd. Thanks Farscape1 for the short instructions.
peteus, newbi, Uznamer, sipdude, Baeckman, francsal, hasanpb, robiom, geloczigeri, najx, cuberiordan, Iemand, Sync_One, Bsoft2007, vonkarayan, 080200, hilt_m, maikal, csjanne, daflux, oldpal, kidde15, Hugo32, ricav, Ohamn, Riederan, 45cube38, BigMihca If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/07/07
newbi said
HiI'm still on the official 2.04 and I can't save web pages to my google account also I can't sync my web pages from google to tablet!
Anyone else having this problem?
I am not exactly sure what the problem is. Are you using Android native browser or Chrome for Android? Can you explain the process please (what it should and what it doesn't do)?
2013/04/16
Hi, i've had same issue with (27/07) version.
Can you check if Settings/google account/ you have everything checked to sinc?
2013/04/16
newbi said
HiI'm using the native browser and in the settings for sync web pages is not there.
I will try chrome now. This is only problem now.
Ok, it's not a rom issue, google stop support other browsers.
Still you can do what i do to mine... Just install "ChromeBookmarksSyncAdapter.apk" on system/app...Restart. Worked for me.
Bsoft2007
The following users say thank you to Bsoft2007 for this useful post:
Farscape1
2013/04/30
2013/04/16
2013/04/03
@admin. Many thanks for your great job! Now the keyboard works normally. I was trying also stock firmware and there was latin keyboard working well but I could not use Polish diacritical marks.
For the time being everything is working nice except HDMI screen timeout. It never worked and looks like never will. It's realy sad. Luckily it can be overcome by means of "Screen Standby # Root" appk.
2013/07/07
If stock android keyboard for some reason is missing some feature, I would like to remind that you can download "Google Keyboard" which is a newest and full version with all languages and features (including sliding/swyping) of stock keyboard but available in play store as a stand alone app. I would actually suggest using app version as currently provided stock version for our tablet is old.
2013/06/19
Is there any difference between this version and the previous "non-official" multi windows version?
As far as I see, it's basically the same, with the difference of the "old" one being a bit more stramlined? Or are there any under the hood differences?
In the "old" windowed version I stumbled upon an issue, that prevents me from using multi windows adequately. Whenever I use Kingsoft office in a window, every time I use the on screen keyboard, the typed text disappears and only comes back when the keyboard is closed. Happens with both the stock keyboard as well as the most recent google keyboard. With external keyboard, there is no problem at all. Any chance to see if that behavior has been corrected here?
I'm assuming that performance-wise is the same. Am I correct?
Thanks in advance for your answers!
2013/04/29
Hi Guys.
I am unable to use this ROM as the Google keyboard would stop responding as soon as I turn on the unit (straight from flashing the ROM). I tried to reflash but the same thing happened. Had to settle for the 7/27 release while waiting for feedback.
Hope anybody can help.
Currently Online: andreive
67 Guest(s)
Devices in use: Desktop (59), Phone (9)
hans41
rickybk
soniya07
ironmangitar
