Here is an Android 4.2.2 Jelly Bean rooted firmware for the Cube U30GT2 tablet based on latest beta update released 2013/05/15
(酷比魔方四核豌豆2安卓4.2系统(Evalution)_20130515-Beta版ROM.rar)
Kernel: Linux version 3.0.36+ (cdy@mid-server) (gcc version 4.4.3 (GCC) ) #85 SMP PREEMPT Tue May 14 11:33:47 CST 2013
Android 4.2.2 JB: rk30sdk/rk30sdk/rk30sdk:4.2.2/JDQ39/eng.szc.20130514.214821:eng/opinions-on-teclast-p90hdst-keys
According to the manufacturer, this beta firmware brings the following changes (Google Translate from Chinese):
1. Compatibility enhancements;
2. optimize overall system operation fluency, and enhance the user experience.
- root with latest SuperSU version 1.25 (free version)
Download: kasty-cube_u30gt2-422-20130515-rooted2.zip
Please flash with Rockchip Batch Tool 1.6, use Restore button.
takkaros, SZULIK, robiom, sipdude, fiji, ebeb2 U30GT2, Baeckman, uscool, Bsoft2007, geloczigeri, redejo65, Reini, alcippi, xploz, vildkatt, dj192dqsdA If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
You can also leave feedback if nothing is wrong, so other forum members does know the firmware works fine
takkaros If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/05/02
Just installed this firmware. I had the last one before that, which in overall was also smooth. I only installed antutu and Skype till now. My antutu score is 15080 (lower than the stock 1.03 16500 but 100 more than the previous beta version). The problem in Skype is now solved. The front camera works as it should. I am also using Swype which lagged a bit in 1.03 but now it's super smooth. I will test video playback and more things tomorrow. WiFi also seems a bit more stable and fast. Thanks again for the release
2013/04/30
2013/05/16
Everything does work fine, much better than stock 1.03 firmware that came preinstalled. The only issue is the wifi as other already have mentioned. Keeps disconnecting while i am 6-7 meters away from the router. I hope this is a firmware issue since it doesn't occur with everyone!
Besides that, thank you very much for providing this Rom. Nice job!:)
2013/05/02
takkaros said
You can also leave feedback if nothing is wrong, so other forum members does know the firmware works fineEverything does work fine, much better than stock 1.03 firmware that came preinstalled. The only issue is the wifi as other already have mentioned. Keeps disconnecting while i am 6-7 meters away from the router. I hope this is a firmware issue since it doesn't occur with everyone!
Takkare (Greek? ) have you tested the tablet with another router? I tested mine with the home router Fritzbox 7140 and does not disconnect even behind walls or doors closed. I tested also with cheap repeaters and then i had lower speeds but not disconnections.
2013/05/16
I flashed this Roms this evening. Testing it i found out that some apps although they are installed i cant open them. I don't even have the option to press open. Example titanium backup.
The rest is working a lot better than the 1.03. Video at 720p is working pretty well, although you get to see some glitches from time to time.
2013/05/16
fiji said
Takkare (Greek?
Ναι Νίκο, Greek-Cypriot to be exact! Actually I tested it under a Speedtouch router and a Hitron BVW-3653. Never had any issues on any other devices ( and we have quite a lot of them connected
). Btw is there anyway to preserve data when going from one update to another ? It doesn't format just the system partition as i was experienced with other android devices. Instead it formated everything, including /sdcard where all the photos, titanium backup files e.t.c are located.
77 Guest(s)
Devices in use: Desktop (71), Phone (6)
