[ ROM ] Cube U30GT2 Android 4.2.2 custom root firmware (beta version 2013/04/25)
robiom
Norwich, UK
Advanced Member
Forum Posts: 124
Thanks Received: 27
46
2013/05/01 - 21:19
Still having problems with cwm install. All went well until reboot and the stock rom was reinstalled. I entered the command chmod 644 install-recovery.sh while in the system/etc/ directory but it said no such file or directory!
Any pointers would be great.
Rob
47
2013/05/01 - 21:22
I'm looking for testers for a new CWM Recovery install procedure.
I let you post in this topic if you are interested:
http://www.arctablet.com/blog/forum/cube-u30gt2/clockworkmod-cwm-recovery-on-the-u30gt2-testers-wanted/
ecki2k
Forum Posts: 22
Thanks Received: 8
48
2013/05/02 - 08:12
You can ignore that,  our rom doesn't contain this script so its properties can't be changed. Just move on with the next steps.
Concerning WiFi disconnects: I found an app named Regpo Wifi Keepalive in a thread for the 1.05 FW and gave it a try... Seems to work,  3 hours of continous streaming via mobile router,  not a single disconnect.  Will check it out further to exclude coincidence but wanted to share early on, maybe it helps someone ;-)
vonkarayan
Thanks Received: 4
49
2013/05/02 - 09:53
I suppose you mean the stock recovery, not the full rom! ;)
By the way, what were the outputs of the shell command you had input?
robiom
Norwich, UK
Advanced Member
Forum Posts: 124
Thanks Received: 27
50
2013/05/02 - 12:18
Hi @vonkarayan
Yes, just the stock rom. Reboot took longer than usual that's why I thought it was restoring the stock rom.
Didn't get any outputs from the commands, it just accepted them (I'm assuming....always dangerous) and returned to the # command prompt.
Should there have been??
Rob
ecki2k
Forum Posts: 22
Thanks Received: 8
51
2013/05/02 - 14:12
Yes, there should´ve been a feedback á la "Recovery written sucessfully" or similiar. You can try if it´s installed by booting up while holding the volume+ - key and power pressed.
If not, why don´t you try the new method of admin linked above? Maybe that works more flawless for you.
robiom
Norwich, UK
Advanced Member
Forum Posts: 124
Thanks Received: 27
52
2013/05/02 - 15:21
Succeeded using the RK Flash Tool and flashed the image to the partition direct. Done my first backup so feel much better lol
Rob
ecki2k
Forum Posts: 22
Thanks Received: 8
53
2013/05/02 - 17:50
Good for you :)
On the WLAN-thingy: If someone with disconnects on a particular router may test if Regpo Wifi Keepalive helps, I´d be quite thankful :) Did another 1-hour-test today, looking good so far.
ebeb2 U30GT2
Australia
Forum Posts: 36
Thanks Received: 9
54
2013/05/02 - 23:32
hey,
I have been using Regpo Wifi Keepalive for 3 days now and it works for sure. But it consumes a lot of battery so beware.
DarthJabba
Forum Posts: 551
Thanks Received: 396
55
2013/05/04 - 13:09
I've never had any wifi problems with this router, regardless of the ROM being used.
strafigo86
56
2013/05/04 - 16:02
how come I can not see the video?
I can not see it on youtube filamti it on other Internet addresses. I have to install something?
HELP ME PLEASE!
DarthJabba
Forum Posts: 551
57
2013/05/04 - 16:27
Which video?
Magnifico
Forum Posts: 25
58
2013/05/04 - 18:56
Absolutely NONE problems here with WiFi!
I set it to sleep...and when I wake it...it reconnects...ALWAYS!
My router is a FritzBox 7390.
Only thing is the joke of a performance that Wifi has....I think it is the reception...700kb/sek from my Synology DS1512+ is not really fast...
My "old" Note1 is 100-150Kb/sek faster at the same spot and same file.
ecki2k
Forum Posts: 22
Thanks Received: 8
59
2013/05/04 - 21:21
Ok, another 3 hours of streaming with the zte device and wifikeepalive, all's fine.
Thanks for sharing,  ebeb2,so the app seems to fix wifi disconnects.  Though I have to say, they're not affecting everyday use anyways as reconnects are fast, it's only streaming video. Didn't check throughput so far cause my old fritzbox sucks at wifi.
Overall, this beta is promising. Give us a new one, Cube :-)
Edit: @strafigo86: Indeed, which video?
hawkdroid
60
2013/05/07 - 19:22
Hello,   i have flashed the 4.2.2 beta too.  Nerly everything is working fine.  But yesterday i have noticed,  that my interlocutor get an still picture by skyping with the frontcamera.  With the backcamera everything is working fine.  Has anyone of you the same problem.?
51 Guest(s)
Devices in use: Desktop (47), Phone (4)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
