[ ROM ] Cube U30GT2 Android 4.1 custom root firmware v 1.05 (2013/04/15)
Thanks Received: 264
2013/05/06 - 11:07
you need to think on the architecture of the processor, the frequency and many other things
On a desktop at 3.2 ghz a 1 percent is 320 mhz on a rockchip at 1.6 ghz is 160 mhz
slymeas
2013/05/08 - 12:22
I have upgrades my tablet to 1.05 fw, and everything went fine.
The tab rebooted, but the screen isn't responding anymore..  so i can't get any further...
Helllp please !!!
ebeb2 U30GT2
Australia
Forum Posts: 36
Thanks Received: 9
2013/05/08 - 12:30
Hey,
     Did you try flashing the firmware again. Make sure you read the flashing instructions again before flashing.
splugh
2013/05/08 - 17:36
you need to think on the architecture of the processor, the frequency and many other things On a desktop at 3.2 ghz a 1 percent is 320 mhz on a rockchip at 1.6 ghz is 160 mhz
Oops.  I apologize, you're absolutely correct.  I thought the CPU load was displayed like in Linux, where 1.00 was 100%, but ADB verifies that you're right -- 1.00 is, in fact, ONE percent CPU load, which is perfectly acceptable.
Thanks!
airman
Milano
Forum Posts: 33
Thanks Received: 5
2013/05/09 - 22:00
Hi, I'm happy to report another successful flash of this ROM.  I tried the 4.2.2 too, but this ROM is a lot better, more fluid and without bugs.  Thanks a lot.
designminder
2013/05/11 - 18:24
very good ROM! Absolutely better than the original ROM (1.03).
I have a bad experience with this ROM. Fortunately only one and it happened only one time!
So, I wanted to shut down the tablet and I clicked on the "yes" button and it said "shutting down..." and I didn't wait for completly shutting down and I put into its leather case, so I didn't see what happens on the screen anymore.
And after half an hour I noticed that it still showing "shutting down..." and the entire tablet was very very hot. I was very scared, so I did a long press on the power button thereby it shut down finally.
I wrote down because this failure maybe made by this new ROM's mistake.
supperka
2013/05/12 - 10:59
Hi all,
I have big problem with touch screeen on tablet look at video .It this ROM problem or hardware?
https://www.youtube.com/watch?v=c968QS1L5_Y&feature=youtu.be
bebertii
2013/05/12 - 11:21
@supperka
Since capacitive touch screen works with electric charges in your body, I guess the problem come from an improper isolation of you power supply, some parasites perhaps. Did you try to test your bug in another place than your home ?
The following users say thank you to bebertii for this useful post:
Thanks Received: 3171
2013/05/12 - 11:28
supperka,
As bebertii suggested it may be an hardware / electrical problem, but it may be worth checking with another firmware is if the problem is still there.
If you want to try latest beta Android 4.2.2 release, it's right here:
http://www.arctablet.com/blog/forum/cube-u30gt2/cube-u30gt2-android-4-2-2-custom-root-firmware-beta-version-20130510/#p22525
supperka
2013/05/12 - 11:32
Yes I tried another place, but this problem is not always.
Always i have problem when use 3 and more fingers.
Ok i try 4.2.2 ROM
Edit:// So i tried 4.2.2 Rom an maybe is problem resolved ;)
But i see new problem tablet tablet is sometimes switch itself off
Al
Forum Posts: 19
Thanks Received: 4
2013/05/16 - 00:24
I have the same problem with version 4.2.2.  Where you able to fix it?  I tried different versions of Netflix and it does not work
Help needed, I love this firmware, the tablet is excellent with it.
maxxouille said
I installed this firmware on my cube tablet. Since then, Netflix is totally unusable (see screenshot). Any idea about what might cause this?
MaxxIMG_20130502_205552.jpgImage Enlarger
maxxouille
2013/05/17 - 20:15
No Al, nothing new round here. Just let me know if you find something. I may try a new firmware based on 4.2.2 firmware. It's supposed to improve video playback
maxxouille said
maxxouille
2013/05/18 - 20:59
No improvement at all...
maxxouille said Hi,   I installed this firmware on my cube tablet. Since then, Netflix is totally unusable (see screenshot). Any idea about what might cause this?   MaxxIMG_20130502_205552.jpgImage Enlarger
thatoneguysomeplace
Forum Posts: 29
Thanks Received: 9
2013/06/13 - 17:44
Netflix did the same thing for me as in the other posted screenshots (lots of video-tearing). Ruining the whole experience.
Not much of an improvement from the standard 1.03 Cube had shipped my Hardware rev 3 model with. That version played Netflix just fine.
66 Guest(s)
Devices in use: Desktop (57), Phone (9)
swan12
heftpflaster
