Here is an Android 4.1 Jelly Bean rooted firmware for the Cube U30GT2 tablet based on latest update version 1.05 dated 2013/04/15 (U30GT2_V1.05_20130415.zip)
Build info:Â
Kernel:Â Linux version 3.0.36+ (zhansb@tchip-super) (gcc version 4.4.3 (GCC) ) #10 SMP PREEMPT Sat Apr 13 11:08:36 CST 2013
Android 4.1 JB:Â rk30sdk/rk30sdk/rk30sdk:4.1.1/JRO03H/20130410.184115:eng/release-keys
- root with latest SuperSU version 1.25 (free version)
Download:Â kasty-cube_u30gt2-411-105-rooted.zip
chamallows, invictus, wipert56, vildkatt, hamsho84, solyfugo, raulmaysel, BigMihca, Bsoft2007, thatoneguysomeplace, cuberiordan, matickoficko, lager If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2013/04/22
I confirm..this firmware is better than 4.2.2 soft for my tab, more fluid, no bug....thank you !
But wifi seems to have problems, not for the signal level (very good !) But with the data speed while uploading a big file.. the speed is irregular (900kb/s to 10kb/s by exemple)..is there a patch to solve this ?
2013/04/20
@chamallows : I don't think there is any rom without wifi issues : I received mine with 1.03 firmware with a very low signal, I experience some deconnections with 1.04 and I'm praying to have no deconnection with this 1.05 firmware.
There is obviously some work to do with wifi and fortunately it seems that updates are regular !
2013/04/28
When i lock my cube 30gt2 and leave it alone for 10-20 minutes the wifi is turned off and in the settings i have cheked that wifi will never turn off when the tablet is in standby...Â
can somebody help??? what should i do better?
And: i feel realy sorry for my worse english, but i am a german user and the germans are very stupid in learning other languages...
SORRY
SORRY
SORRY
I hope i can hear from you soon...
erni
2013/04/30
Hi my german friend.
I have the same problem with wifi. its turns off when the screen turns off. I used this app from play store and it fixed the problem. but it still show weak wifi signal at home.
https://play.google.com/store/apps/details?id=jp.miraidou.regpon.wifi
Happy to help.
2013/04/26
If you go to Developer Options->blahblah->Show CPU usage, you can see that the load average is consistenly above 1.0, largely due to "system_server". Â I think this is a bug in some versions of Android 4.1, where the auto-rotation feature is broken and keeps cpu usage at 100%. Â The general fix is to disable screen auto-rotates, but this ROM doesn't have that feature in the Settings menu. Â Anyone have a fix?
2013/04/30
It is normal for any computing device to use at least 1 percent of the CPU
2013/04/28
hi,
im Heer again...
thanks for your answers! The APP has fixed the problem!
but the stupid german "android-user" has another question...
is there any possibillity to overclock the CPU??? may be to 1,8 or higher...
and don't say the cube has got 1,8 GHz becuase it's wrong...
if you download setcpu or no-frills CPU control, you will see that the highest possible frequency is 1,6 GHz !!!
if this was impolite, i fell very very sorry for it but my english isn't the best... just keep in mind, that everything i'm writing here is ment as polite as it could be!
thanks for your help or informations
2013/04/27
The load average on mine is always above 1.0, which corresponds to 100% of cpu usage. Â (As a rule, that's per-cpu; since the RK3188 has four cores, it would go up to 4.00 for "all cores fully occupied.")
My Xoom, for example, is showing a load at idle of 0.14, which is common for Linux-based devices. Â My Galaxy S3, on the other hand, is showing an unlikely 7.73, and I'm pretty sure it's not doing anything more stressful than showing me my lock screen. Â On a desktop device, a load average of 1.0 isn't a big deal, but it means somebody's occupying the CPU.
Currently Online: manumerayo
83 Guest(s)
Devices in use: Desktop (63), Phone (20), Tablet (1)
kuzin
Dag58
montolla
portvein
POELE
hststs44
