We've just published a rooted version of a beta Android 4.2.2 firmware for the Cube U30GT2.
Please let us know if it works any betterÂ
2013/04/12
strafigo86 said
HELP ME!!!Since I bought the tablet can not connect to wifi, I can only connect to the hotspot to iphone4, but no wifi router, all the routers. I tried already with 8 different routers.
I can see the network wifi, but can not connect I've tried everything, new firmaware, reboot, password removal, reboot the router, nothing. help me please!FROM ITALY, REGARD GIUSEPP
I have exactly the same problem HELP HELP
2013/04/24
strafigo86 said
I just installed the new firmware, very nice, but the problem has not been resolved. I fear it is a mistake factory
Maybe the antenna inside is not correctly plugged ?!Â
If you tried with several firmwares, sure it is an hardware issue.
You said that you can only catch the iPhone 4 wifi access point.
Maybe only wifi B Â or wifi G works .... or maybe only one channel..
Custom Cube U30GT2 rooted firmware based on version 1.05 just posted:
2013/04/17
strafigo86 said
No, it does not work with no Wifi with a router. I do not know really how to do, the problem is not solved. I am very discouraged. I have the tablet for a month and I still have not been able to use it as it should. Help Me please!
There are 2 ways to solve this WIFI problem
First: is to send your tablet to the seller for repair or exchange ..this is the worst solution.
Second: there is a workaround to get very fast internet connection in your tablet,..it will cost you around $10
          All what you need is 3 things connected together,...
           a)- RJ45 ethernet cable
           b)- OTG min usb host cable
           c)- USB to Lan RJ45 ethernet adapter
You can search on Ebay for these items.
Connect all the 3 items together and connect the free end of the RJ45 cable to your Router and the OTG cable to your Cube.
- Go to setting-->Wireless & Network--->More...--->Ethernet..and check "Use Ethernet".
Now you have a direct ethernet connection to the router and you are ready to surf the net with a blazing fast speed...The downside though is you gonna be tied to your router depending on the length of your RJ45 cable,..and the Cube will be acting as mini desktop computer .
Hope this can help to resolve the internet connection problem in your Cube.
Cheers
2013/04/15
mgrgs,....The above advice is about how to  connect  to the  Internet"
with a 'wired solution'Â but not how to resolve a "WiFi" problem.
But since you brought up the above scenario - I wonder if the following would work:
and then connect it to this:
(not saying it will work, just wondering myself. Because if the tablet would recognize theÂ
wireless external USB adapter ($4.99 on eBay) via micro USB/USB adapter ($1.99),
this would be a cheap (while not the most elegant) solution.
146 Guest(s)
Devices in use: Desktop (142), Phone (4)
