[ ROM ] Cube U30GT2 Android 4.1 custom root firmware (v 1.03)
dilan154
2013/04/18 - 10:11
Power down the tablet, unplug USB cable.
On top of my head, as I don't have a Cube U30GT2 for the moment, Push Vol+, plug the USB Cable, keep Vol+ pushed and push Power.
When you reflash, make sure to use Restore button in Rockchip Batch Tool.
Phew, finally fixed it!!! Cool
Thanks for all your suggestions guys, nothing seemed to work. Finally I downloaded the supersport 1.1 ROM for this device. It didn't work either but then I tried doing the manual 'EraseIDB' in the RKTool that comes with the supersport ROM. This completed successfully and then I flashed the supersport ROM successfully. Might try flashing the arctablet ROM again later but for now I am happy having a functional tablet Laugh
Thanks Received: 3171
2013/04/18 - 10:21
Using Restore button as we recommend in Rockchip Batch Tool does pretty much the same as EraseIDB button in RKTool, that may be something that you missed.
dilan154
2013/04/18 - 10:28
Tried using the Restore button 3 times as you recommended when trying to reflash - this did not work. I guess the RKTool is just a little more reliable in this regard.
mgrgs
2013/04/20 - 06:55
After successful updating the v1.03 rom, everything went very good except the wifi, still can't connect to my router ,although it detect it but, no internet connection...any suggestions on how to resolve this wifi issue..is there any specific settings in the router need to be changed ...
Thanks Received: 264
2013/04/20 - 10:59
try to change the encryption, the channel, try to remove the password
2013/04/20 - 11:22
You may also want to try firmware version 1.04 that is supposed to bring some WIFI improvements.
I believe it's a beta as Cube hasn't published it yet on their website.
mgrgs
2013/04/22 - 03:06
Thanks, but it didn't work. The only way for my wifi to work again is to buy a new router...using the same encryption it did connect and was able to navigate the net. Your help is really appreciated though.
thatoneguysomeplace
Forum Posts: 29
Thanks Received: 9
2013/06/13 - 17:51
My U30GT2 Hardware Rev 3 unit (replacement) shipped from Cube with 1.03 firmware standard, and it is the only version of the firmware that was able to play Netflix streams (without video-tearing).
The only funny thing is, after flashing to different ROMs, even flashing back to ANY of the 1.03 versions left me with a frozen touchscreen. (Go figure). The remedy? Flash a different version build of ROM, and the touchscreen works again, but then; no Netflix. :-<
You win some, you lose some. Hope the kinks get worked out with the 4.2.2 series (or with Netflix's app running on Rockchip ARM CPU/Mali GPU units soon)
55 Guest(s)
Devices in use: Desktop (53), Phone (2)
wheaten156
luislx
algua
Twotrains
alexanddercrb
tsmfallen
