2013/03/16
Hello
I have a 32 Gb sd card. It's an original Sandisk, not a no-name; I validated it on several devices, Android and Windows.
When I try to use it on my U30 GT2, it does not work properly, without reliability.
The tablet can't read the files correctly, stops, hangs...
If I copy files with my tablet by USB and try to read them, it fails. If I copy files by another mean (USB adaptor for instance), verifiy them, mount the card on the tablet and try to read them, it also fails.
I tried to reset it several times with my tablet, format it in FAT32, no improvment..
My firmware is U30GT2 4.2.2 20130606 (v2.03).
Did anyone experienced this kind of problem ?
Thank you !
2013/07/09
I have a 32Gb noname sd card, I have been able to download pictures and music from usb to pc and from wifi, also from my cloud storage. Is that a new card? Mine was out of the package and fat32 it through my vista version pc. I also have another that I 32fat from a win7 pc. both work fine, one of them went from my tablet to my sons ste phone with no additional work on it, It worked fine. You might try a new one if you havent. If it is or it does not work keep looking on here, some one will come by.
chantmeMost Users Ever Online: 803
65 Guest(s)
Devices in use: Desktop (56), Phone (9)
hans41
rickybk
soniya07
ironmangitar
