Which firmware is running? Which Flashtool used to flash this firmware? CWM?
2014/03/20
The firmware is custom rom Dukerth, but I have the official rom too, but my tablet is cube U30gt2 Mh, and now the rear camera Not work, not work the flash and the picture looks fuzzy it can be?
is bricked and I had to unbrick with making a bridge circuit and it started, but when reassembling the lid had been taken off the camera and then looked blurry
I used flashtool Rockship 1.7, but I try with CWN, but it is not possible, failed...!!
How i can repair the rear camera, and it looks bad, but the front camera looks good.
and how install the kernel...
can you help me Oma??
Install this via CWM: http://crewrktablets.arctablet.com/?wpfb_dl=2174
Is that KitKat running?
Ah, ok. The U30GT 2MH kernel is a JB kernel. KK needs a selinux kernel to boot. So, you can use this kernel only in JB builds.
Yes. When the JB builds comes as update.img this is the way. Otherwise change the kernel before flash.
Be aware that you have to change the loader first when you try to downgrade from KK to JB.
First change the loader. Then flash the JB image.If not included install CWM. Then install kernel via CWM.
2013/11/24
mohag519 said
I messed up and I would really sell my kidney for anyones backup of the u30gt2MH firmware. Please can someone send it to me?
Found this Firmware here:
http://chinagadgetsreviews.blogspot.com.mt/2015/08/download-android-jelly-bean-422-stock.html
used second "here" link (only this one works).
It opens here:
http://www.filefactory.com/file/5ff2sjacdudt/U30GT%202MH%20V1.00%2020131128MIPI.rar
It is claiming that it is the firmware you need but I had no time to check and confirm it yet.
365 Guest(s)
Devices in use: Desktop (88), Phone (277)
JEssicannn: 279
AnnaStockm
IAmTheOne86
tkowalski
Devlin
gitidi3813
goliad
Topics: 6129
Members: 266802
