2013/07/09
2014/03/20
The tablet works fine, but I'm told on the website of this cube has an improved firmware, which of course is not posted on any site, and banggood, and they said no more would be made, then I would be rewarded with € 30 sending me another version I guess ....
2014/03/20
As for the CWN I install ArcTools, for that I had to root the phone, and before you have to make a backup of the system, and clear as I did not find the firmware, install the aforementioned 20131029, but q to root and then install ArcTools, 4.2.2 and from there to the CWN, but to make a backup md5 mistake gave me, so I have HTCMania q in q answer proque error, and trying to install from external sd.
2014/05/24
First it's a CWM Backup I made before flashing.
Second I don't know what you did but flashing one of the normal U30GT2 Firmwares out of this forum didnt brick my tablet.
Third I would first have to figure out how to delete that personal data out of my backup or change my passwords on facebook etc.
Damasta,
About your personnal data, the easiest thing is probably to backup your data, then reset the tablet (Settings / Backup & reset menu / Factory data reset), make sure app program and data are gone and then make a new CWM backup.
2014/05/24
using the method above i could only give you a backup of the new firmware I have now but the display is working well for me.
I've got that one, gonna make it throughout the day because I'm busy.
//edit: you can try flashing it yourself in the meantime since it worked well for me.
Cube U30GT 2MH - Kernel lincp #21 preempt 28 Nov 2013 now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=2170
2014/03/20
Cube U30GT 2MH - Kernel lincp #21 preempt 28 Nov 2013 now in the archive: http://crewrktablets.arctablet.com/?wpfb_dl=2170- Oma -
Hello...
I have cube U30GT 2MH , but with rom to cube U30GT2, it works well, but how I install this kernel ?? could you explain me please...!!
Thank you
74 Guest(s)
Devices in use: Desktop (68), Phone (6)
